Previous in Forum: Mold texture   Next in Forum: Sizing Return Air Grilles
Electronically controlled variable valves?
02/21/2007 2:11 PM
Hi... I have an inventive idea that requires several small electronically controlled valves to restrict or fully stop the flow oil with the approximate viscosity of 10W40 motor oil.
I am guessing the maximum pressure they would have to resist would be about 5 bar. Its size must not be greater than approximately 15mm dia.
Does anyone know of such an 'off the shelf' device? ...Regards, JD
Good Answers: 247
Re: Electronically controlled variable valves?
02/21/2007 3:07 PM
Yes, the ON - OFF valves are commonly called solenoid valves, or solenoid-operated valves, and those that can vary flow smoothly are usually called proportional control valves. Search via Global spec and google.
Reply to Forum Thread
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
