Previous in Forum: ISO 320 oil viscosity   Next in Forum: Straightening Copper Tube
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Utility Station
06/15/2010 8:53 AM
Can you please explain whether we need an isolation valve in case of placing utility station (other than the one whihc we provide for the hose connection) as shown in the figure above.
If required then under what conditions & if not then why not??
Please explain.
Atul singla
Good Answers: 61
Re: Utility station
06/15/2010 11:34 AM
Your sketch is "Right", "Correct", and "Proper" for ALL normal Utility Station installations.
Yes, you need the "isolation" valve (nearest to the header) in case there is a break in the line near the ground. Remember, near the ground there will be traffic in the form of people, and the moving of machinery. There will also be stress placed on the utility line connections by some worker pulling on the hose connected to the coupling. Then "SNAP" there goes the line and you need a second shut-off with out shutting down the whole unit or plant.
Yes, you need the valves down near grade because you don't want the maintenance people climbing up in the pipe rack every time they want to turn on or turn off a utility service. You also don't want "Maintenance" mad at you for making their work harder or more dangerous.
Do it once and do it right
Re: Utility Station
06/15/2010 9:45 PM
Thanks for the explaination. But i n my case, the utility line's length is hardly 3 metres and header is at 3 meter high.
Do i need to provide another isolation valve near the header as i have provided the valve at the hose connection.
Atul singla
Re: Utility Station
06/16/2010 10:56 PM
The attached drawing is extracted from "The Piping Guide" by David Sherwood, Figure 6.12, and we consider that drawing as a standard design for a utility station. Please read the full Article 6.15 from the specified book.
Register to Reply 3 comments
Abdel Halim Galala (1); PennPiper (1); singlaatul (1)
