sir ,
how can i test the winding resistance with out giving DC supply to HT transformer ? and how can i test the HT transformer load losses instead of going to short circuit test? please tell me detail matters and analysis.
thanking you
Winding resistance of a transformer cannot be measured without applying a voltage/current (usually DC) to the transformer. We typically use a DC power supply capable of putting out 3 amps at up to 24V, measure the voltage drop across the winding with a digital multimeter, and do the Ohm's Law math. Primary windings are often in the range of several tenths up to an ohm or 2. Secondary windings will usually be in milliohms, seldom as high as half an ohm, based on a lot of transformers I have seen over the years.
Load and no-load losses are based on design and manufacturing parameters and materials, and should be provided by the manufacturer. They are typically not measured in the field. The Mfr of the transformer should be able to provide that data for you, and they should be on the original test reports for the unit.
It is just off topic but I like to use this forum as I am
observing a lot of People from middle east are using this forum and
making life
miserable for others if they have guts please respect knowledge .
"Once there was a
lion who was in his country zoo having a good meal life .once there was a
oil
middle east sheikh visited the zoo .The organizers proudly show the lion
to oil
middle east sheikh . The oil middle east sheikh liked the lion very much
and
the other lions said to lion you are lucky they are taking you to best
place it
will be like heaven .The lion felt proud and finally the oil middle east
sheikh gave a large amount of money and transfer it
to Middle east ZOO .1st day they give him bananas 2nd
day
he got bananas third day things difficult for him he was dying with
hunger he
shouted at the zoo guys "WHY ARE YOU GIVING ME BANANAS DONT YOU KNOW
WHAT A
LION EAT " the attendant replied --please note it – "YOU ARE ON A
MONKEY VISA SO SOLONG AS YOUR VISA IS YOU ARE A MONKEY "
"---Moral of story please check your visa before travel to middle east
may be
they give you a monkey visa .
Please please please they are making life a hell for expatraites and
if you are thinking to support them
I don't understand your problem Ferth - but if as I suspect, you are saying your countrymen are an embarrassment - you might be the bigger embarrassment - or monkey, as you seem to be implying.
But I could be misreading the "wall to wall arrogance" your post seems to convey.
However; if you'd like to know how to competently post an image, perhaps read one of the threads on "how to".
when we perform transformer winding resistance test by omicron kit why the injecting current should be 10A or below is there any reason behind this and how can i determine the WR result is there any clculation if any pls give me example
