Previous in Forum: Dexpan Non Explosive Demolition   Next in Forum: Grant-Writer Needed
Raymond Mill Working Principle and Maintenance
06/20/2010 6:12 AM
Raymond mill
Raymond mill is one main products of our company .And as one of the biggest production base in China, our company have produced the Raymond mill with better wom in the Raymond mill market. And abiding by the enterprising spirit of "quality first" and service principle of "customers primary" ,we company have put forward the operation idea of "good faith and truth seeking ".
Working principle of Raymond Mill
Raymond mill are mainly applied to crush the barite, limestone, ceramic, slag with the Mohs hardnes of less than 9.3 degree and the super thin powder process of over 280 materials in the non-flame and explosive field of mining,metallurgy,chemicswith the moisture of lower than 6%. And the final particle size can be adjusted at the range of 60-325monyh and some materials can reach the extreme high degree of 500monyh.
When Raymond mill working ,the materials will be delivered into the machine body by the feeding hopper installed on the sidewall of the cover shell.Abiding by the roller equipments swung on the star rack of the main machine body,it will make the revolution movement by surrounding the vertical axis and make the autorotation movement at the same time .Due to the centrifugal force ,the roller will swing outside and give much pressure on the gringing ring so that the shovel can deliver the materials to the space between the roller and ring,thus achieving the crushing aims.
Raymond mill Maintenance and Repair:
1. Prior to installation of the equipment, all the people who will be assigned to operate the equipment have to be technically trained to know the principle and rules of operation. Someone should be specially selected and put in charge of the operation.
2. To ensure normal operation of the equipment, a manual containing strict rules and procedures for its operation, maintenance and repair should be well prepared and followed. Tools, replacement parts for maintaining, repairing and lubricating oil and grease must be available for immediate use.
Re: Raymond mill working principle and maintenance
06/20/2010 9:52 AM
This falls under the heading of crass commercialism.
But then I guess you don't really care, do you Bozo?
Reply to Forum Thread
You might be interested in: Roller Screws, Roller Bearings
