Previous in Forum: Heat-Activated Clothing   Next in Forum: Power Boilers and Accessories
Engineering Fields - Transportation Engineering - VTOL nut
Shipbuilding Automation
02/22/2007 9:51 PM
where I work, ships are built in blocks, i.e.: each block is fabricated, painted in workshops and hauled(with a multi wheel flatbed) to the dock and joined by welding(no glue allowed!) to form a ship and floated out.
Each block maxes out at abt. 450 tonnes, this is the max handling capacity of gantry cranes here, which lifts these blocks and holds each one in place until it is welded enough to be released.
Everything involved in the above process is highly labour intensive, but amazingly accurate!.
To automate the above,..
I'm working on an automated cell abt. 30mx30mx30m, completely sealed(total or partial vacuum), and each side(total 6) shall have its own 3-axes crane with provision for robotic arm(s), tools, etc.
Question here is, any given block is very complex, vis-a-vis fabrication. My challege is to come up with robotic arm(s) arrangement that could be set-up ,on the fly, to handle material handling(steel plates), local preparation(wire brushing/grinding etc), actual welding, and painting.
I've look at using indoor GPS to guide the robotic arms with reference to relevant drawings. Besides these blocks are put together within sub-milimetre tolerance(yeap! otherwise the client would simply reject em'!).
What changes or process(es) do I need to change/introduce to the get above done.....
knowledge is like love; the more you share, the more you receive
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Shipbuilding Automation
02/23/2007 4:51 PM
rmg21,
While your own cell referenced "GPS type" system will be fine for overall positioning, when it gets down to specific operations, or precision assembly, I recommend that you employ "fixturing aids" (precision locating points) on the individual parts and a means for for your positioning system to reference off of them. One such technique would involve a separate precision robotic "arm" whose only purpose was to establish the relative positions of the parts to be joined. Another method would be precisely locating optical transducers along the joint on both the stationary part and the part being positioned for joining. Emitters and detectors would be a combination of wide angle and narrow angle devices to provide the required positioning feedback during the critical last phase of locating the part being moved.
I know nothing of your specific project, but in general, positioning parts such as you are describing, relative to each other is much more accurate when you actually reference them against each other, rather than both separately off a "distant" set of references and then calculating their relative positions, which works well only until you get in the "ballpark" where much higher precision is required for final positioning. The accumulation of errors is small in relation to general positioning, but will turn out to be larger than the precision you require for final joining.
Hope this provides some food for thought.
Regards, Greg
Good Answers: 39
02/24/2007 7:23 PM
RMG21 wrote: I've look at using indoor GPS to guide the robotic arms with reference to relevant drawings. Besides these blocks are put together within sub-milimetre tolerance
REPLY
GPS relies on a very faint RF signal coming from orbiting satellites. Steel structures, especailly grounded steel structures tend to block GPS signals. Even the best survey grade GPS is not intended to work at sub millimeter accuracy. Been there done that with survey grade equipment and a local Differntial signal transmitter for hydrological and land surveys.
Robotic guided factory systems usually rely on positioning information by picking up on signals emitted by buried wires in factory floor. It works much like the digitizing tablets used to digitize a manual drawing or a photograph. Only difference being the larger escale. Another method used for overhead cranes is similar to the linear positioning scales used on milling machines and five axix CNC machining centers. The crane knows the exact position of the hoist point of the hook by referenceing how far along X, Y and Z axis the crane has moved and raised or lowered the hook.
A third method is laser referencing ( range finding) the clamping arms use to hold the parts being assembled.
As Greg mentions, a less expensive method would be a coarse positoning system referenced to the building envelope and a high precision system referenced to mating points of the sub assemblies. It would also be more flexible to accomodate varying assemblies.
Elnav
Elnav
02/26/2007 3:23 AM
Thanks for input guys,
........input so far has been rather high level...large shipbuilding plates could be real pain for such automated fabrication, add normal metalwork practices,...gas cutting, grinding etc, and the pre-welding works in cell could pile up, - How do I overcome/rid of these!?
Also, inspection by client inspectors..
Elnav, thanks for your input, but I think indoor GPS is a self contained system;
http://www.qualitydigest.com/feb05/articles/01_article.shtml
02/26/2007 9:56 AM
You may want to check out some of the techniques utilized in the aerospace industry that have been developed to allow for fixtureless assembly. Basically this involves incorporating features on the various components which allow for self-alignment that is verified using laser trackers.
Good Luck.
Robert
Register to Reply 4 comments
Anonymous Poster (1); elnav (1); Greg G (1); rmg21 (1)
You might be interested in: Robotic Tool Changers, Terminal Blocks
