Previous in Forum: Class of Valve   Next in Forum: Difference Between EN8 Vs C45 Material
SAW Contact Tip - Material
06/23/2010 3:43 AM
Friends..
Can you suggest an ideal material (with chemical composition) for Submerged Arc Welding (SAW) contact tip, which have better machinability, wear resistance and conductivity.
pk
Good Answers: 18
Re: SAW Contact Tip - Material
06/28/2010 9:42 PM
The contact tip must be
a good conductor of electricity,
have good mechanical strength and hardness to with stand heat,
minimum tendency to combine with filler metal.
There are may varieties and good one among them are:
1. Copper 99.2% (+) Chromium 0.80% - has high mechanical properties but low thermal and electrical conductivities than Cu (+) Cd alloy.
2. Copper 99% (+) Cadmium 1% - high strength and harness coupled with good electrical and thermal conductivities.
3. Copper 97.5% (+) Beryllium 0.5% (+) Nickel 1% (+) Cobalt 1% -
4. Special alloys made of copper (+) Zirconium and copper (+) cadmium (+) Zirconium.
Generally, type 1 and 3 are commonly available.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
06/29/2010 6:45 AM
Thanks Mr Sridhar....
I will try it and let you know my observations.
pk
You might be interested in: Saw Blades, SAW Filters, Angular Contact Bearings
