We are producing a sheet metal part which is blanked, formed and then heat treated. The material is CK60 a high grade steel. The thickness is 1.3 mm. Width and length dimensions are 80X50 mm. After heat treatment the blanked section bows and tip sections deform upwards.
The defect rate is %40 for each lot. What may be the problem.
Thanks.
