Previous in Forum: transformer   Next in Forum: help me
short calculation with solved example
06/25/2010 9:56 AM
how i can calculate the short circuit current if my MDB Main breaker is 1600A AND transformer is 1000KVA AND lenght is 72m
Re: short calculation with solved example
06/25/2010 10:07 AM
Check here. This is a straight forward example.
http://ecmweb.com/mag/electric_shortcircuit_calculation_methods/?smte=wr
Good Answers: 170
06/25/2010 10:20 AM
Assuming that the transformer secondary is 433V and the percentage impedance of the transformer is 4%, the short circuit current for a three-phase fault would be:
(1000 x 1000) / (Root 3 x 433 x 0.04) = 33,335A or 33.33kA.
Note: It is assumed that the 72m is the length of the bus dust whose impedance is neglected in the above calculation. If the bus bar impedance has to be included or if the 72 m shown is that of a cable from the transformer to the panel, then the cable impedance has to be considered and the fault current will reduce considerably. But, the above value can be taken as a safe design.
06/25/2010 10:21 AM
For short circuit rating you have to take into account %age impidence of the transformer, rated voltage is to be known as well.
Length of cable or bus duct provides additional limiting impidence however motors contribue and if the motors are of large size there will be considerable effect.
Without going into detailed calculations 30 KA short circuit rating at 400 volts works well with 1000 KVA and is widely practiced.
Symmetrical short circuit current formula with only the transformer under consideration is as follows:
Symmetrical Short Circuit KA = In x 100/%Zt
Knowledge sharing is a WIN-WIN situation
Good Answers: 11
06/25/2010 12:29 PM
See this pdf and it will help you step by step.
http://www.bussmann.com/library/docs/EPR_Booklet.pdf
electricalexpert65 (1); Hameedullah Ekhlas (1); mountk2 (1); wareagle (1)
