Previous in Forum: Borewell Water Filter   Next in Forum: 1991 Isuzu Amigo Fuel Pump Problem
13 comments
1997 Cavalier Won't Start, Crank Sensor ODB
06/26/2010 1:34 PM
1195 Cavalier onn the way to scrap. ODB says crank sensor. mech broke it in the block trying to remove it. he replaced the ingition control module, no spark still- he says. any idea?
Re: 1997 Cavalier won't start, crank sensor ODB, mech broke trying to remove
06/26/2010 1:43 PM
See the "Search this Forum" box to the right? Type Cavalier won't start in there. You'll have dozens of instant friends here.
They must have only built these on Mondays and Fridays.
06/26/2010 1:43 PM
More info. Sorry OBD testing not ODB. 1995 Cavalier. Ignition Control module with the 2 packs, he kept the orginal packs on the module. Thank you.
Good Answers: 60
06/26/2010 3:51 PM
you have the worlds most useless unreliable car.
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=cavalier&order=asc
there are hundreds of links there all about cavaliers
Good Answers: 60
06/26/2010 3:55 PM
did he replace the crank sensor?
Good Answers: 60
06/26/2010 4:05 PM
1195 Cavalier onn the way to scrap if i was you i would let them have it sorry
sorry but from what ive read about these cars since i joined this forum since febuary i think there must be hundreds of these cars that make really good door stops.
  1. Cavalier Problem Diagnosis - Automotive Message Forums 1991 Cavalier 2.2L - Rough idle, unresponsive accel. starting from full stop. ... New car disaster! 91 cavalier runs lean after warms up · ONE signal light ...
    www.automotivehelper.com › ... › Chevrolet › Cavalier - Cached - Similar
  2. Preloved | uk vauxhall cavalier - cars reviews PREVIOUS CAR: Cavalier 2.0i 8V (j reg) - Cannot fault, extremely reliable, copes with extreme abuse with ease. Not the most comfortable of cars, ...
    reviews.preloved.co.uk/fuseaction-reviews...315/0164634d.html - Cached
  3. Chevy Cavalier Car Repair Questions and Answers Chevy Cavalier Car Repair Questions and Answers Professional Mechanics Online will answer it FREE ... Scan your computer for fault or error codes. ...
    www.2carpros.com/makes/chevy/cavalier.htm - United States - Cached - Similar
  4. Chevy Cavalier Car Repair Questions and Answers Question: 1991 Chevy Cavalier. My car will start strong and drive well until the .... Answer: Scan the computer for fault codes first. If no fault codes are ...
    www.2carpros.com/makes/chevy/cavalier2.htm - United States - Cached - Similar
  5. Vauxhall Cavalier Mk III - review and opinion - Most reliable car ... Which may be a half decent car, but has a hell of a lot of faults that need ironing out before it will be as reliable as the Cavalier. Rate this review » ...
    www.ciao.co.uk › ... › Vauxhall Cavalier Mk III › Reviews - Cached - Similar
  6. Chevy Cavalier Repair Manual - Chilton, Haynes - 2005, 2004, 2003 ... Haynes Repair Manual - Paper 1995-2004 Chevrolet Cavalier. HAYNES REPAIR MANUAL -- 320 pages; .... Chevy Cavalier Car Bra · Chevy Cavalier Car Cover ...
    www.car-stuff.com/...cavalier/repair_manual.html - 18 hours ago - Cached - Similar
  7. Vauxhall Cavalier Fuel Fault - Yakaz Used cars 8 Jun 2010 ... vauxhall cavalier fuel fault, vauxhall cavalier red 1992 5000 mi diesel central locking electric windows k reg vauxhall ..., vauxhall ...
    cars.yakaz.co.uk/vauxhall-cavalier-fuel-fault - Cached
  8. Cavalier automatic gearbox fault after engine changed 9 posts - 3 authors - Last post: 8 Mar 2009Goto the cavalier how2 section. and look for fault codes .... code and in 10 minutes I am going back at the car to see .... fingers crossed. ...
    www.vauxhallownersnetwork.co.uk/showthread.php?...Cavalier...fault... - Cached [Cavalier Mk3] [88-95] Cavalier Auto, transmission whine‎ - 4 posts - 2 Mar 2010
    Fault code reader 10 pin to 16 pin conversion‎ - 7 posts - 5 Jul 2007
    immobiliser p1503 fault code‎ - 4 posts - 16 Nov 2006
    More results from vauxhallownersnetwork.co.uk » Get more discussion results
  9. Cavalier Automatic - Donkiz Car Queries related to "cavalier automatic" : left side steering wheel from uk. Read your Engine Fault Codes, Reset Fault Codes, (Car Fault Code Reader Scanner ...
    car.donkiz.co.uk/used-cars/cavalier_automatic.htm - Cached
  10. Vauxhall Cavalier Gsi running problems - Used Car Forums 4 posts - 2 authors - Last post: 18 Jun 2007Vauxhall Cavalier Gsi running problems Ask the mechanic.
    www.usedcarmart.co.uk/forum/showthread.php?t=13093 - Cached Get more discussion results
Searches related to cavaliers car faults
chevy cavalier car
cavalier car problems
1
6
7
8
9
10
Next
Re: 1997 Cavalier Won't Start, Crank Sensor ODB
06/26/2010 8:04 PM
We /I don't like to pick on people when they try to accomplish something, but how did he manage to break the sensor? It has an o' ring around it and sits in the crankcase bathing in oil. I have replaced a few and never had any problem removing them. They are a little awkward to get at, but not impossible to remove. I'm wondering if all these problems people are having with these vehicles aren't mechanic induced. Before I would condemn it to the salvage yard, get a second opinion.
h
Good Answers: 123
06/27/2010 12:52 AM
Here's a second opinion. The car is ugly also.
If the sensor is useless already, treat it like a broken bolt. Drill into it, and set an easy out into it and start turning it. Two things may happen. 1) it strips out and makes the hole bigger. If that happens, use a bigger easy out, or go to drywall screws, the course thread variety. Once you have a good bite on it, pry it out.
Option 2) it bites into the sensor and the sensor starts to spin. Once you have it spinning, start to lift and pull at the same time.
On the other hand, if you want to test weather or not the new sensor is going to make the ignition work, that is easier. Just plug the new sensor in, and turn the ignition switch to the on position and pass a good sized screwdriver across the sensor. If the coils start to fire, continue to work at removing the sensor. Good luck. I have owned two of these car designs. One ran for years until my daughter tried to see if air cooling would work. The other one is still stashed away for future use.
Bob
06/27/2010 8:17 AM
I love your sense of humor and agree completely with your procedure for removal. Your suggestion to check for spark is right on the money. Good advice! Somehow I detect a hidden respect for this model since you are saving one for future use. Could it be you are counting on something to keep you busy? Have a great day !
h
Good Answers: 60
06/27/2010 9:09 AM
its probably cheaper than getting a hobby
Good Answers: 123
06/27/2010 9:57 PM
Actually it was an impounded auto that I had to repair in the impound yard. I submitted a bill for repairs, and had to put a lien on it. It is a Baretta model with the hot (?) 3.4 engine. I have three daughters. One of them always needs a car. I spent a few years at GM dealerships, and find them filled with less annoying surprises.
Bob
07/02/2010 3:03 PM
If he replaced the Crank Sensor and ignition module. Did he replace the coil packs? If so check the ECM fuse in the fuse panel.
08/24/2010 10:26 PM
ya'll are what i like to call redneck back yard mechanics. first off dont drill into it. needless to say shaving will end up clogging just about eveything and then your replacing more then needed. heres what you do go and get a oil pan gasket and some blue rtv and some earl to replace all that u lose. besides the point your car could prob use a new gasket anyways its prob leaking like all do. so now that u have your ac motor pulled lower engine bracket and your started off take your pan down and push that rusted corroded nasty plastic sensor out the back of your block........ Heres your sign!!! (larry the cable guy)
Good Answers: 123
08/26/2010 1:19 PM
Fail. Fail. Fail. Wrong member of the Blue Collar Comedy Tour.
Go ahead O great nameless one. We have all been so impressed by your grasp of the subject, procedure, typing and grammar skills.
Bob
Anonymous Poster (5); bob c (3); lyn (1); peterg7lyq (4)
