Previous in Forum: Recycling Vegetable Oil Waste   Next in Forum: Electrostatic coating
American Equivalent for British steel
02/23/2007 11:52 AM
Does anyone have any information on a british low-alloy high-strength steel designated as "EN 11". In particular, I am seeking a domestic equivalent. Thank you.
Good Answers: 27
Re: American Equivalent for British steel
02/24/2007 11:13 AM
The best I can do is recommend a couple of sources. ASM International (www.asminternational.org) publishes a Worldwide Guide to Equivalent Irons and Steels. It's available both printed and on CD ROM. Unfortunately I no longer have a copy.
Another possibility is www.steelspec.org.uk. They have a cross reference of European standards (which I believe EN 11 is) to other international standards.
Good luck.
02/26/2007 11:50 AM
Thank you.
United Kingdom - Member -
02/26/2007 3:50 AM
If it's of any help; BS970:1966 included EN11 then, when the standard was revised, it became BS970:1970 grade 526M60. When the standard was revised again in 1983 there was no direct equivalent given. I no longer have any copies of the early standard so I can't give you the composition but I have found from a brief search that it contains 1% Chromium.
I hope this helps
02/26/2007 11:51 AM
Thank you
02/26/2007 5:13 AM
En 11; 0.5-0.7%C, 0.1-.035%Si, 0.5-0.8%Mn, 0.5-0.8%Cr, 0.05% max S, 0.05% max P
02/26/2007 11:53 AM
Thank you.Can you steer me to your original source?
Register to Reply 6 comments
ad016 (1); Anonymous Poster (1); Bluestone (1); edalder (3)
