I have some plate and frame heat exchangers used on board a sea going vessel that have seawater on one side and distilled water on the other side. Currently I am using a chlorinator on the seawater side to fight biological fouling on the heat exchange surfaces. The heat exchangers work in pairs (one on-line with the other off-line) that are swapped once a week. The system requires a lot of man-hours to operate. The off-service heat exchanger is required to have flow through it for an hour a day to flush it with chlorinated water to keep biological fouling to a minimum. Basicaly I'm looking for some ideas on a less man-hour intensive method for fighting the problem of biological fouling. Any ideas?
