Previous in Forum: Recycle/Reuse Methods of Old Cartons   Next in Forum: Material Selection Book
Phenolic Epoxy Lining System
07/04/2010 2:55 AM
what is phenolic epoxy lining system at pressure vessel inside
Re: phenolic epoxy lining system
07/04/2010 11:03 AM
Paint, probably formulated to be used on the inside of water tanks or other vessels. System refers to the method of preparation and application.
Re: Phenolic Epoxy Lining System
07/04/2010 12:04 PM
It's difficult to tell exactly what you are talking about based on your post, but, if you go to the Sherwin Williams web site, they have an extensive array of industrial coatings, each coating system is described, and includes msds sheets, technical details, etc. Whether you are trying to determine what you have or what you need, you can probably find your answer there.
07/04/2010 10:50 PM
See the attached datasheets:
• Pitt-Guard® Phenolic Epoxy lining 95-267 Series
07/04/2010 11:07 PM
• For chemistry of phenolic, see the following site: http://search.4shared.com/q/1/Phenolic
07/04/2010 11:19 PM
thanks
in conclusion, cause of phenolic epoxy painting vessel's inside is corrosion protection. correct or uncorrect ?
07/05/2010 12:45 PM
Correct
07/05/2010 11:40 PM
thank you
Register to Reply 7 comments
Abdel Halim Galala (3); kramarat (2); mkbj1205 (2)
