Previous in Forum: Mido   Next in Forum: Maximum Runs On A Busbar According To Standards
Good Answers: 11
Saturation
07/05/2010 5:47 AM
Greeting all,
Can any body give me some information regarding to saturation consideration difference in salient pole machines and iron rotor turbogenerators.
Re: Saturation
07/06/2010 10:46 AM
Kindly be more specific in your query. What aspect of design consideration you would like to know. Salient pole generators are slow speed generators and therefore have more number of poles as compared to non-salient (also known as cylindrical pole) Turbo Generators which are high speed machines having mostly 2 poles ( for nuclear application some times 4 pole generators are also used). Because of higher speed, the diameters of Turbo Generator rotor is restricted and therefore have limited cross section area for flux path. But this restriction is overcome by increasing the length.
Saturation depends on the flux requirement which in turn depends on number of stator slots, voltage generated, parallel paths, and many other factors.
I may be in a position to reply your question with specific queries.
Good Answers: 11
Re: Saturation
07/06/2010 11:27 AM
Thanks and I found my answer in google.
Register to Reply 2 comments
You might be interested in: Rotor-Stator Mixers, Stepper Motors, Magnetic Bearings
