Previous in Forum: Pneumatic Transmitter Panel   Next in Forum: Dirty Diesel
Is It Possible To Use The WPS Of A120B Instead Of A216 WCB?
07/06/2010 1:23 AM
Would it be possible to use the WPS of A120B INSTED OF A216 WCB? The A216 is used for check valves in oil industry whereas A120 B I checked the chemical composition of these to metals and I did not see any outstanding differences. The first one is cold draw and the second is castin iron.
Engineering Fields - Piping Design Engineering - New Member
Re: Is It Possible To Use The WPS Of A120B Instead Of A216 WCB?
07/29/2010 2:08 AM
I believe A120 material has been discontinued and replaced with A53. However, as the P-number is same for both the materials (A120 and A216 WCB), and the filler material requirement is also the same, you can use the same WPS.
Regards,
Ashfaq Anwer
http://thepetrostreet.com
Reply to Forum Thread
