Professional Data Transmission expert. E-Lins Technology providing CDMA Router, Gprs router, M2M Wireless, EDGE Router, 3g modem, Hsdpa router, EDGE router, Hsdpa Modem, hsupa modem, Gsm Modem, 3g router, gsm router etc. E-Lins WiFi router support 2.5G/3G/3.5G different classes of mobile cellular technology. E-Lins products are mainly used in industrial remote control, environment monitor, water schedule, traffic, oil field, weather forecast, environmental protection, street lamp control, post, bank, CCTV, security surveillance, and many other areas
If your line connection there is no problem Yeah this problem solved . Are you using Telecom ADSL, and if so , the problem is too simple. If the speed dial access to the Internet with the Star is ADSL. Then I teach you how to use the Internet M2M Wireless routers. First of all, you do not use the first router to connect two computers , you first use the original desktop computer with the correct dial connect to the Internet . Open: Control Panel → Performance and Maintenance → Administrative Tools → Event Viewer → System Just connect to the network when the system is your first telecommunications encrypted account number, password unchanged . The above will show ~ + English names or numbers + area + phone number , users connect to the network information . This is your correct account number , that is, the system automatically pulls the correct account number . The second step is to set the Wireless routers, use the router to connect two computers using IE to enter into the URL is 192.168.1.1. General router into a user name and password are admin. Enter the setup wizard to use Event Viewer to generate the password for the account and set the dial original user name . Inside and then set the boot and automatically dial when disconnected . The third step is to set the IP. Open My Network Places → View Network Connections → Local Area Connection Properties → Properties → Internet Protocol automatically obtain IP, DNS address option select → OK . OK, what the problem hi
