Previous in Forum: Welding Copper to Steel   Next in Forum: Potting Compound
Rain Gauge Dimension
07/07/2010 2:51 PM
Dir Sir,
Can I please send me that what is the real dimension of rain gauge.
Re: Rain Gauge Dimension
07/07/2010 7:37 PM
My rain gauge has the dimensions of a tuna fish can.
Seriously, a rain gauge can be any container with a flat bottom and vertical sides.
Rain Gauge
Good Answers: 101
07/07/2010 8:06 PM
A rain gauge can have any dimensions, but it is better to use a tall thin cylinder with straight sides and flat bottom so that the amount collected can be seen more clearly. The best thing for you to do is to magnify it by calibrating it. First, get a funnel. Next, get a beaker of the same Ø as the mouth of the funnel. Fill this beaker up with several inches of water and then pour it into you tall narrow cylinder. Divide the level of water into equal spaces. Next drain away the water and place your funnel in its mouth. Finally, place your cylinder outdoors in an open area where it can collect rain.
I hope this will help you with your little science project.
You might be interested in: Weather Instruments, Pressure Gauges
