Previous in Forum: Testing of Power & Distribution Transformers   Next in Forum: Over Heating of Cable Terminal
Difference B/W PLC & CNC
07/12/2010 6:58 AM
What is main differences between PLC & CNC's ?
Good Answers: 266
Re: Difference B/W PLC & CNC
07/12/2010 7:16 AM
PLC refers to automated machinery in it's use of Programmable Logic Controls. CNC refers to automated machine tools and it's Numeric Control. I most cases a PLC is used in a CNC to obtain that numeric control. CNC term is usually only used in those machines used to machine parts.
07/12/2010 8:57 AM
Just add one point that wasn't covered. The first word of CNC is computerized. As ozzb indicated, there may be other ways to "control" a numerically controlled machine than using a PC now.
Good Answers: 804
07/12/2010 11:56 AM
Another issue however is the sophistication of the control capability. CNC systems imply full machining capability, including the "gold standard" of coordinated motion control, "interpolated motion"; the coordination and simultaneous execution of complex curve machining using 3 or more axis of motion. Most PLCs are not capable of that without adding motion control modules to them. On the other hand, a CNC system is probably incapable of any kind of process control such as PID loops, which is something a PLC can do. So in essence you can place a PLC into many different control platforms, including being part of a CNC system, but a CNC system is dedicated to a specific task even though that task may be inherently something that a PLC needs help with.
07/13/2010 6:48 AM
GA !!
CNC use a much complicated algorithm for calculation, while PLC are simpler, they are more LOGIC than Arithmetic
dont say it, write it
Register to Reply 4 comments
JRaef (1); Le_Noble (1); lyn (1); ozzb (1)
