Previous in Forum: Design of Solenoid - High Speed on Moving Axis   Next in Forum: Incommer Selection for mCC Panel
Digital Overload Relay Amp Rating
07/13/2010 3:23 AM
anyone provide the digital overload relay amp rating for 75KW,380V supply motor for one of my project.
please reply me
regards
kamatchi
India - Member - New Member
Good Answers: 164
Re: digital overload relay
07/13/2010 3:48 AM
i assume you are in India. Electronic overload relays are available from the following :
Schneider Electric India
ABB India
CS Electric
and a few others too.
The motor current is about 135 A.
07/13/2010 4:30 AM
Hi kamatchi0515
your motor will draw about 114 A, your overload has to be set at (127 A) as the overload is usually set at "115%-130%" of the rated current of a motor.....this percentage depends on the the motor's power.
I hope this helps
Thanks.
Just live and .. Learn!!
Good Answers: 164
07/13/2010 6:49 AM
Sorry, but 75000/(√3 x 380) = 114A. There is then the matter of PF and efficiency to be considered, which makes it closer to 135-140A.
As the OP's name seems Indian, i assumed she is from India, and if so, the relay will have to be set to the actual motor current, if it sees the full motor current. If it is used in a star-delta starter, the relay will see In/√3 ≈ 80A. Then there is the matter of whether it is a Class 10A, 10, 20 or 30 starter depending on the starting duration. More info from the OP will help in deciding all these.
If i am wrong in assuming the OP's nationality, location and sex, my apologies
Good Answers: 804
Re: Digital Overload Relay Amp Rating
07/13/2010 2:37 PM
I agree, most solid state overload relays require that the setting be at the motor nameplate FLC, the 115-130% is already factored into their trip curves.
07/21/2010 8:04 AM
Hello dear,
The answers were already given for your question. This , you need for a project record or actual installation at the site??
If this relay is required for site installation, collect the motor data sheet from the motor manufacturer. Then note the required fields live FLC,starting time etc and forward the details to the Over load relay manufacturers. Specify your requirement for S/C,O/C etc. He will suggest you the required relay.
PRATAP
Ali18 (1); JRaef (1); kvsridhar (2); nmpratap (1)
