Previous in Forum: Induction Motors vs. Synchronous Motors for Lift Irrigation   Next in Forum: Triple Phase to Split Phase Power Distribution
9 comments
Panel View Printer Help!
07/13/2010 6:52 AM
Hello all, I am new to this forum so greetings to everyone. I need help in selecting a printer to use with an AB Panel View plus 1500 HMI interface. It was my understanding that any HP printer will suffice but, after buying an HP laserjet 1102w I found out that's not true. Thanks!
Quick, hurry up and wait!
Pathfinder Tags: Panel View
Re: Panel View printer help!
07/13/2010 6:59 AM
Do AB recommend any particular type? Do they specify what interface is needed?
07/13/2010 7:03 AM
They claim that any printer (usb) that uses PCL3 language will work.
Good Answers: 29
Re: Panel View Printer Help!
07/13/2010 8:01 AM
Make sure all your Comm settings are correct.
07/13/2010 8:29 AM
Did that. I've gone through the printer config many times. Any ideas on a different printer? We have determined that the 1102w is not compatible.
07/13/2010 11:14 AM
We found out what would work from our AB vendor. Thanks for all the help guys!
07/13/2010 11:05 PM
Would you please share your info from AB with the rest of us.
Thanks
repeat problems can not be solved by the same way of thinking ( A. Einstein)
07/14/2010 7:18 AM
USB Keyboard
Texas InstrumentsDP860USB6189-KBDEPU1UNo√√√
BelkinF8E885No√√Generic USB keyboard
MicrosoftOffice-X08-72446No√√
Aopen90.00029.58UNo√√√
OrtekMCK-600USBNo√√√Generic USB keyboard
Rockwell Automation6189V-KBDEPU1No√Serv A, Rev A Used with a Iogear USB to PS/2 Keyboard & Mouse Adapter GUC10KM All keys work on both Mozart & Raptor
Rockwell Automation6189V-KBDEPCU1No√Serv A, Rev A Raptor- F13, 14, 15, 16, 17 on keyboard, produce F15, 16, 17, 18, 19 on screen Key F18-20 produces nothing as a result Keys F21-24 can not be tested, software doesn't have the option to Conclusion- 2nd row of Function keys not working properly- all others ok Mozart- upon plugging in the keyboard the Caps lock, Num lock, & Scroll lock are illuminated and no keys work.
Rockwell Automation6189V-KBDEPU1UNo√Serv A, Rev A Raptor- All keys work Mozart- upon plugging in the keyboard the Caps lock & Scroll lock are illuminated and no keys work
DellRT7D10No√√√
LogitechEliteNo√√
USB Mouse
LogitecM-BJ58No√√√
MicrosoftIntellimouseD58-00026No√√√
AtekOptical MouseACC-MS15000No√√
VersaView (RA)Mkt "giveaway"No√√√
USB
Keyboard/Mouse
Combo
SolidTekACK-540UNo√√
Texas InstrumentsDU-5K-USB6189-KBDEPC1UNo√√
USB Hub
Belkin4-port HubESU021No√√√
USB Mini2-Port HubNo√√√
Adaptec1495179-00No√√√
USB Memory Sticks
SanDisk
SanDisk Cruzer Mini USB Flash Drive - 512 MB
SDCZ2-512
No√√New 2/25/2005. This drive takes about 12 seconds to be usable by the terminal.
Kingston
DataTraveler USB Flash memory drive 512 MB
KUSBDTI/512
No√√New 2/11/2005. This drive takes about 12 seconds to be usable by the terminal
Intel128MNo√
IOMega128MNo√
Kingston128M/256MNo√
GE32MNo√
SimpleTech Bonzai32MNo√
USB Printers
HPHP PCL3 PRINTERHP Deskjet 5650OBSOLETENO√√√
HPHP PCL3 PRINTERHP Deskjet 5651OBSOLETENO√√√
HPHP PCL3 PRINTERHP Deskjet 5440OBSOLETENO√√√
HPHP PCL3 PRINTERC8970A (HP Deskjet 6940)OBSOLETENO√√√PanelView Plus firmware revision must be at 5.00.04 or higher or the following error message, "Unidentified USB device" will appear when plugging in the printer. This will not affect functionality.
HPHP PCL3 PRINTERC8969AB1H (HP Deskjet 6980)OBSOLETENO√√√
HPHP PCL3 PRINTERHP Deskjet 6988OBSOLETENO√√√
HPHP PCL3 EnhancedHP Deskjet 9800OBSOLETENO√√√
HPHP Deskjet D730OBSOLETENO√√√
HPHP Photosmart D5360OBSOLETENO√√√
HPHP PCL3HP Officejet Pro 8000NEWNO√√√New added in HCL v2.2
HPHP PCL3HP Officejet 6000NEWNO√√√New added in HCL v2.3
OKI DATAOKI DATA B2400NO√√√
See CommentsSee technotes: ID30068, ID 28334, ID35179√√√Only printers that support Printer Control Language (PCL3) will work. Printer that support PCL4 and PCL5 may not be fully backward compatible. Non-PCL should support ASCII-only printing with the default PCL driver. In the past, we have found that HP 57
USB Bar Code
Scanners
Symbol TechLS4004I-I100 (Gun)STI185-0200 (cable)NoG58832160√√
Intermec3-650039-02 (Gun)3-604038-00 (cable)NoG58832160√√
Hand Held ProdImageteam 38003800LR-12USBKITNoG58832160√√
USB Drives
TeacUSB FloppyFD-05PUWNo√√√Problem if disk is removed when attached to the PV+/VVCE. Must disconnect and reconnect drive if disk is removed. Addressed in ME 4.00.10
LaCieFloppy70618 MYFLOPPY3No√√Problem if disk is removed when attached to the PV+/VVCE. Must disconnect and reconnect drive if disk is removed.
EXPCD -RWCRW-880UNo√√Only works when powered from USB port
KingstonPCMCIAFCR-U2ATANo√√
ADS TechnologiesDVD/CD DriveUSB DVD DriveNo√√
CompactFlash
Memory Cards
Smart Modular32MSM9FLACF32M62711P-RC1No√√√
Smart Modular64MCU105271784-CF64No√√√
Smart Modular128MSM9FLACF128M52711P-RC2No√√√
Smart Modular256MSM9FLACF256M52711P-RC3No√√√
Smart Modular512MSM9FLACF512M12711P-RC4No√√√
Sandisk32MSDCFB-32-101-812711P-RC1No√√√
Sandisk128MSDCFB-128-101-812711P-RC2No√√√
Sandisk256MSDCFB-256-101-812711P-RC3No√√√
Sandisk512MSDCFB-512-101-812711P-RC4No√√√
CompactFlash
I/O Cards
Socket CommsSerial IO8010-00087 CNo√√
Socket CommsModem8510-00180 CNo√√
Socket CommsEthernetEA2902-139No√√ Also can use Socket EA9200-117
Socket CommsEthernetEA9200-117Yes√√ Also can use Socket EA0911-101
USB Serial Port Adapters
KeyspanUSA-19QWNoG52054637√√
USB Misc Adapters
Tripp LiteUSB to ParallelU206-006-RNo√√USB to IEEE Parallel Printer Adapter, USB-A male to Cent36 male
Black Box Network ServicesUSB-CAT5 ExtenderIC244A-R2√√√The remote unit of the USB-CAT5 extender enables you to connect two full-speed or low speed USB devices
IO GearMiniview III
4-port USB KVM
GCS1774No√√√
Here you go. The list of compatable printers is not very long...
07/14/2010 6:32 PM
Thanks for sharing!
Dave
07/15/2010 6:07 AM
No prob.
Register to Reply 9 comments
007 (4); Anonymous Poster (1); dthomas16 (2); JohnDG (1); RDGRNR (1)
