Previous in Forum: Conversion factor of NM3/hr to m3/hr   Next in Forum: Pump Flow
Scissors Lift Analysis
07/14/2010 8:42 AM
I need to balance the forces i.e tension and compression on a double scissors hydraulic lift table with a maximum load of 250kg and height of 1.80m. I need to know all about using an axial or piston pump in a scissors lift.
Good Answers: 266
Re: Scissors Lift Analysis
07/14/2010 2:26 PM
Balancing is done with flow dividers. Everyone that I have worked on used a gear pump.
Reply to Forum Thread
You might be interested in: Lift Tables, Lift Stations, Axial Flow Pumps
