Hello,
I have a question about the deterioration of the power factor of a VFD operating under reduced loads. Typically, the input current on each line of a 3-phase VFD will exhibit peaks corresponding to when the input voltage is above DC bus voltage. Under reduced load (i.e. lower VFD output current) these peaks will be sharper due to the fact that the DC bus loses less charge and the input voltage is higher for a shorter period of time.
Does anyone have any quantifiable data/graphs/waveforms to illustrate the extent to which this happens on a typical VFD and, more critically, how reduced power affects the distortion power factor?
Thank you in advance for your help,
Pawel
