Previous in Forum: Solar Water Geyser Performance Evaluation   Next in Forum: Service Temperature of Plastics
10 comments
E-Modulus of FRP Tube
07/14/2010 11:43 PM
I have tested (Cantilever Bending) the FRP Composite tube to know the E-Modulus of the material. The e-modulus value by (E=Stress/Strain) formula and by (E=PL3/3I∂) formula is comimg different. Can anybody put a beam of light on it?
Also posted in: also posted in Mechanical Engineering
Pathfinder Tags: E-Modulus of FRP tube
Re: E-Modulus of FRP Tube
07/15/2010 1:46 AM
What was the equation you used to calculate the stress?
07/15/2010 3:31 AM
M/I = ∑/ Y
07/15/2010 8:55 AM
Ok, what equation did you use to calculate 'I'?
07/15/2010 11:16 PM
I = (∏ / 4)*(R4 – Ri4)
07/16/2010 12:21 AM
Did you make a typo? Or is that the source of your problem?
I = (pi/64)(D^4-d^4)
07/16/2010 12:27 AM
.... also, how did you measure the strain? You aren't intermixing displacement with strain are you?
07/16/2010 12:29 AM
it is one of the same
07/16/2010 12:31 AM
We have measured the strain by strain gauge and deflection by LVDT.
Location: 36-Tariq Block, New Garden Town, Lahore-Pakistan
07/16/2010 12:30 PM
There is no difference between your formula and that used by Mr. Bhagwat. Here is the reconciliation: I = (pi/64)[(2R)^4 -(2Ri)^4)] = (pi/64)(2X2X2X2R^4-2X2X2X2Ri^4) =(pi/64)(16R^4-16Ri^4) =(pi/4)(R^4-Ri^4) So that is not the problem
07/20/2010 4:01 AM
The bending formula is only a derived equation of a homogenous material fitted to the initial portion of the load versus deflection curve. All bets are off with a composite material where local plastic deformations at the load points might be a factor or if its modulus is different in compression than tension. The bending test should give you a good estimate of the flexural strength when the first surface layers begin to yield (or fracture depending on the composite's characteristics).
Register to Reply 10 comments
Anonymous Poster (5); eaaziz (1); Milind Bhagwat (4)
