Previous in Forum: Press Brake Design and Build   Next in Forum: Welded Base Plate
8 comments
parallel piping system
07/15/2010 4:42 AM
i just want to know if in electrical circuit, the equivalent resistance of a parallel circuit is given by 1/Rp=1/(1/r1+1/r2+........1/rn). Then is this relation true for parallel piping also for finding equivalent pressure loss in a parallel piping system? since the parallel piping and parallel electrical circuit is similar.
Good Answers: 21
Re: parallel piping system
07/15/2010 5:37 AM
I'm not an electrical engineer but I think your equation is wrong. It should be
1/Rp=(1/R1+1/R2+......1/Rn)
To be honest I'm not sure if running parallel pipes follows this relationship. Thinking out loud, if I have a header tank with one pipe coming out the bottom and have X flow then I put in another identical pipe I'd get 2X flow. This would mean that the resistance would have halved if the relationship between flow and resistance is linear. Now I seem to remember that it is not so I'd suggest the relationship isn't as simple as the above equation suggests.
Thats my thinking of it. Can someone prove (or disprove) this with calcs?
07/15/2010 5:59 AM
thank u for your comment. yes i was wrong earlier. i maen to say 1/Rp= (1/R1+1/R2+...1/Rn). while designing a parallel piping system with different flow rate in different branch, how would i calculate the pressure differnce. should i use this formula to calculate equivalent pressure loss?
07/15/2010 7:59 AM
No, you can not do like that.
Every pipe branch point have the same pressure.pressure drop in a branch is same as much in another pipe.
if A is the branch point which divided into 2 branch, and B is the branch point that 2 branch mentioned can become unity again. The pressure drop is pd A minus pd B, this value will be equal with Pressure Drop on every branch.
07/15/2010 7:47 AM
Yes, basic principals apply to both systems.
The sum of the flow at a node is zero. Current is analogous to flow. KCL.
The voltage around a loop is zero. KVL.
Replace V=IR with Q=VA and you are good to go.
Use Bernoulli equation to balance potential and kinetic energy plus friction losses.
Did your circuit also contain reactive components (i.e. capacitance and inductance)? You did not say.
Good Answers: 137
07/16/2010 9:22 AM
It's not that simple. In elec case, voltage difference is proportional to current, but for fluid flow pressure difference is proportional flow2 in nearly all practical cases. Also V=IR is Ohm's law, but Q=VA is just velocity x area and doesn't say anything about pressure difference.
But there is a formula analogous to 1/Rp = 1/R1+1/R2+......1/Rn
Calling R1 = ΔP/q12, R2 = ΔP/q22, etc (analogous to R1 = V/I1, R2 = V/I2), q1 = √(ΔP/R1), q2 = √(ΔP/R2) etc. To calculate R1, R2 etc, just take an arbitrary (but reasonable) figure for q, find ΔP by usual hydraulic methods, and find ΔP/q2. Doesn't have to be the common ΔP for the overall system.
qtot = √(ΔP/Rp) = q1 + q2 + ...... + qn = √(ΔP/R1) + √(ΔP/R2) + ....... + √(ΔP/Rn)
So, dividing by √ΔP, 1/√Rp = 1/√R1 + 1/√R2 + ....... + 1/√Rn
Cheers......Codey
07/17/2010 6:04 AM
thanks codey 4 your answer. but i am little confused about the relation Q1=√(ΔP/R1) since the unit of ΔP & R1 are same and is expressed in ft of water in case of a hydronic system designing. please clarify it.
Good Answers: 137
07/17/2010 7:30 AM
Hello khurshid
No, R has units ΔP/Q2. So ΔP/R has units Q2.
E.g. to take arbitrary figures, if ΔP = 10000 Pa at flow 100 m3/h, R = 1000/1002 = 0.1 Pa/(m3/h)2.
Come back if you need more.......Codey
07/17/2010 10:05 AM
I have many times tried to use electrical/hydraulic analogies looking at circuits of each. For the most part they are equivalent.
However, if you want to stretch you mind, examine the units of your electrical or mechanical equations. It is then you may decide on personal limits of inquisitiveness.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
Register to Reply 8 comments
Anonymous Poster (1); Codemaster (2); Coldspot (1); fendhik (1); khurshid_1127 (2); MACA (1)
You might be interested in: Piping Services, Piping Systems, Circuit Breakers
