Previous in Forum: Service Temperature of Plastics   Next in Forum: Electro-Chemical Machining
Teflon Coating
07/15/2010 6:48 AM
Is there any way that I could re finish my aluminum breadmaker ladle so that dough does not stick to it? I do not find an answer on the net. Thanks.
jurie sa
Pathfinder Tags: Teflon coating
Good Answers: 266
Re: Teflon coating
07/15/2010 7:23 AM
Dupont makes a spray on teflon coating that then can be bake to set it. You may find someone local that does it. I know they offer it for heat plates that are used to thermally weld plastics. Also for medical applications. See the links
http://www2.dupont.com/Teflon_Industrial/en_US/products/product_by_type/coatings/index.html
http://www.precisioncoating.com/
http://www.plastechcoatings.com/
Re: Teflon coating
07/15/2010 7:58 AM
This can be solved very simply. Just use MAZOLA Oil Spray
Materials and Process Engineering Guy
India - Member - New Member
Good Answers: 164
Re: Teflon Coating
07/15/2010 11:26 PM
Isn't teflon coating supposed to be dangerous above certain temperatures ? Or has that alarm blown over ?
Register to Reply 3 comments
Bodepudi (1); kvsridhar (1); ozzb (1)
