Previous in Forum: Concrete Cooling   Next in Forum: Using Carpet Fibres to Reinforce Soil
Admixtures - Micro Silica / Fly Ash and Concrete Hydration
07/16/2010 2:10 AM
will micro silica or fly ash reduce heat of hydration of concrete?
Pathfinder Tags: admixtures Civil construction
Good Answers: 29
Re: Admixtures - Micro Silica / Fly Ash and Concrete Hydration
07/16/2010 4:59 PM
Micro Silica is reactive and contributes to the heat of hydration. I believe the initial heat of hydration is higher, resulting in a higher early strength. This is useful in some applications. Sorry, I don't know the actual values in heat per unit mass.
Fly ash however is reactive but contributes less heat per unit of mass than Portland cement. So yes the use of fly ash would reduce the heat of hydration of concrete if used to replace Portland cement in the mix design.
The following are two good references (Not Wikipedia) that will help you out:
Concrete: Scientific Principles
Influence of Supplementary cementing Materials on the Heat of Hydration of Concrete
Si vis pacem, para bellum
