Previous in Forum: High Voltage, 30kv and Low Voltage Cable 400 Volts   Next in Forum: Electrical - Overloaded Generator
NGT and NGR
07/16/2010 2:56 AM
What is a different between NGT and NGR? Which is best to use?
Re: NGT and NGR
07/16/2010 8:26 AM
Green
Reply Score 1 for Off Topic
Good Answers: 58
Re: NGT and NGR
07/16/2010 1:37 PM
The difference is:
NGT is down $0.23 today (as of 12:38PM Central Standard Time) and is publicly traded
NGR is not publicly traded.
Good Answers: 244
Re: NGT and NGR
07/16/2010 1:51 PM
NGR = Neutral Grounding Resistor
NGT = Neutral Grounding Transformer
These are two different things and are used for different purposes. One is not the comparable to or substitute of other. See these threads for the detail about NGR and NGT:
For NGR, see http://cr4.globalspec.com/thread/56612/Neutral-Grounding-Resistor
For NGT, see http://cr4.globalspec.com/thread/36828/What-is-Earthing-Transformer
- MS
Good Answers: 170
Re: NGT and NGR
07/20/2010 9:58 AM
For Low Resistance Earthing go for NGR (Neutral Grounding Resistor) and for High Resistance Grounding go for NGT (Neutral Grounding Transformer) with a low value resistance connected across the NGT Secondary.
Anonymous Poster (1); electricalexpert65 (1); KJK/USA (1); msamad (1)
