Previous in Forum: Water in Fuel - 2003 Ford Focus 2.0 CL   Next in Forum: Building a Train Wheel
9 comments
Brake Design
07/16/2010 5:17 AM
we are in progress of designing a brake for a formula type race car
our car weighs 100kg with max speed 100km/hr , and wheel base 1650 mm
we are using four wheel disc brakes with two seperate master cylinder for front and rear .
can you suggest how to choose which brakes of car be used and its calculation
Re: brake design
07/16/2010 6:41 AM
I would pay money to see the look on your drivers face when you tell him you went to CR4, an online forum, to find out what brakes to use on his race car.
Re: brake design
07/16/2010 7:00 AM
Sorry, I couldn't help myself. You might get some valid info here, but I would get a second opinion before slapping the brakes on the car.
Re: Brake Design
07/16/2010 8:29 PM
I'd get in touch with a go-cart builder and ask him what he uses on his shifter carts.
Or motorcycle brakes.
There's tons of brakes already designed. Why not just buy some?
Re: Brake Design
07/17/2010 9:49 AM
Before we can discuss brakes, we need to come up with the proper design for the wheel.
Hobbies - CNC - New Member
Re: Brake Design
07/21/2010 4:52 PM
I quite agree. At that weight and speed, brakes from a very small motorcycle or from a kart would do just fine. Could even get away with braking only the front wheels. Although, the F900 brakes mentioned elsewhere would be quite resistant to fading. hehe.
too soon old, too late smart
Good Answers: 137
Re: Brake Design
07/17/2010 5:21 AM
Separate master cylinders for front and rear is a novel idea. Will there be a brake pedal for each?
Codey
Good Answers: 123
Re: Brake Design
07/21/2010 6:37 PM
What I have seen of that design, they used a link between the two masters, and varying the link could bias the braking to front-rear as needed.
Bob
Good Answers: 123
Re: Brake Design
07/18/2010 2:08 AM
When I worked for the highway dept, we had some F900 Ford dump trucks. The trucks went for over 5 years, and never wore out the brakes. I think you should use them. I think they were 16" by 6" wide.
Bob
Good Answers: 123
Re: Brake Design
07/21/2010 6:40 PM
Use the smallest, lightest brakes that will just barely prevent fade when used harder than possible on the track.
Bob
bob c (3); Codemaster (1); kramarat (3); lyn (1); RickZillman (1)
