Previous in Forum: Electrical - Overloaded Generator   Next in Forum: Data Concentrator Unit
Earth Rod Extension
07/16/2010 6:22 AM
Please how do i extend my earth rods from 3m to say 6m? besides rod lengths of 3m and 1.5m are thy any other lenght variations?
Re: Earth Rod Extension
07/16/2010 8:34 AM
If you buy a standard earth rod (of any length), one of its end is conical while on the other end there are threads to fit a hammer head socket meant only for driving the rod in ground by hammer strike.
Remove the hammer head socket and apply extesion lengths using sockets.
Practically better results are achieved by using earth rods in parallel, minimum seperation criteria between two rod is lenght of the rod itself.
Knowledge sharing is a WIN-WIN situation
07/16/2010 12:48 PM
Thanks for your ans.If i'm going to use a 20mm diameter eath rod,i guess the rod coupler size should be 20mm too.how do i get the the size of the earthing connection to the rod if i want to use a U bolt (how are U bolt rated)?
Thank you once more
Good Answers: 58
07/16/2010 10:13 AM
Register to Reply 3 comments
benotype (1); KJK/USA (1); mountk2 (1)
