Previous in Forum: Asphalt Station Inspection   Next in Forum: Weld Metal Thickness Question
SMAW and GTAW Welding Process
07/22/2010 12:56 AM
Hi,
I have a PQR which shows a GTAW and SMAW combine welding process. The root pass is weld using a 2.4mm filler rod. The rest of it is welded using smaw. Total thickness of base metal is 7.11mm.
Using the PQR can i create a GTAW only WPS of max 4.8mm thk?
Re: SMAW and GTAW Welding Process
07/23/2010 1:07 AM
Hi
If on the PQR it shows a GTAW and SMAW combine welding process, does this means that for the WPS we can create a GTAW ONLY welding process?
Please advice.
Thank you very much
REgards,
Jess
Engineering Fields - Piping Design Engineering - New Member
07/29/2010 3:11 AM
As per ASME Sec. IX, a change from one welding process to the other is an essential variable and requires re-qualification.
Regards,
Ashfaq Anwer
http://thepetrostreet.com
08/05/2010 2:52 AM
Yes.You can create seperate WPS for GTAW as well SMAW ,subject to covering SEC.IX essentail variables.
