Previous in Forum: Electrical Colour codes   Next in Forum: Formulaes to Design Magnetic Couplings
Solar Power Panel Installation
03/01/2007 3:01 AM
I am thirumalai. I am interested in electrical saving and production field, so I want solar panel idea and how to install properly. How to connect the load (battery stored ofter) using directly load at AC or DC?
Re: Solar Power Panel Installation
03/01/2007 11:13 AM
Dear Sir,
I am interested in ur problem, and i have also some solution for it.
U connect the output of the solar cells to the bettry(depends upon the solarcells output, most probably it will be DC).
Connect this output to the DC filter.
Connect the output of the filter to the DC LOAD.
Or if your load is AC then conver the DC filter output to inverter and then connect the output of the inverter to AC load.
u can contact me on surag1982@gmail.com
regards
surag
03/02/2007 2:40 AM
Hey, you do better than me.
Explain me the DC filter and why it is in.
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
03/02/2007 12:13 AM
Thirumalai,
There is almost unlimited information on the web concerning your very general question. Using a search engine (Google or the like) is the way for you to accomplish this, not to ask others to do that initial, and most basic task.
Regards, Greg
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
03/02/2007 10:24 AM
Greg, I understand your frustration.
It would be better to give the child the first tip,
for example:
use Search: Solar Power Panel Installation. (this Underlined text to be typed!)
"Search" has usually a field where you may type your problem (as above) then press/click a button which is mostly just to right of the field with a question/problem.
From the displayed list select one answer and maybe next one if you did not get what you expected.
03/03/2007 7:46 AM
Let's reveal a secret, kept for ages, given through from father to son: www.google.com
Gwen
03/08/2007 2:14 PM
http://www.solarenergy.org/resources/store.php
This book is a good one for solar energy theory and application.
Anonymous Poster (2); Greg G (1); Gwen.Stouthuysen (2); southern123 (1)
