Previous in Forum: Use of Studs in Place of Bolt   Next in Forum: Design Challenge: How to Increase Force from Linear Motor?
Does This Material Exist?
03/01/2007 6:46 AM
please cna you kindly tell me if this material exists and where as well as cost, can i find the piece ?. sorry it is given in french. ( CONTROLEUR DE DEBIT A PALETTE , DEBIT>200L/MIN PALETTE EN INOX , TEMPERATURE<60 DEGREES c,
INDICATEUR VISUEL PASSAGE EAU CONTACT INVERSEUR 110 VCC, 5A0
REGARDS
TUCO
Re: Does This Material Exist?
03/01/2007 9:25 AM
Come on, it's not so hard...
It's just a flow controller for flows > 200 L/min. Flap type, in stainless steel. Actually, works like a "switch". Work temp less than 60 degC. Visual flow indicator and electrical connection for up to 110 VCC 5 A.
Now, check globalspec. I'm sure you'll find some product like that.
Humm... suspicious you are...
03/08/2007 3:17 AM
I hope nobody energises your relay!
03/01/2007 11:11 PM
This is a Flow sensor w/a SS-rotor for 200LPM or 53 a Gallons per minute to control an inversor, I believe this inversor is on a pump to control the rpm to control the flow of water at temp < 60 centigrade degrees (look for a conversion table to convert to a F) an a visual indicator, the inversor control a 110 VDC at 5 Amps motor and may be a analog signal comes from the flow meter to the inversor, and of course exist.
03/02/2007 10:10 AM
i don't know why
i've got a feeeling . . .
did i see some of these devices this morning at the petrol station ?
Anonymous Poster (2); bhrescobar (1); Paulcardo (1)
