Previous in Forum: API-653 AST Minimum Shell Thickness Determination   Next in Forum: Software
To Purchase Any Type of Pump
07/29/2010 8:37 AM
what are the systematical parameters given to vendor for purchasing pump in the market
Re: to purchase any type of pump
07/29/2010 8:47 AM
You can download a pump worksheet here:
Pump Worksheet
There are other sites that offer the same type of help, this is just one.
Good Answers: 137
Re: To Purchase Any Type of Pump
07/29/2010 11:17 AM
The obvious ones - flowrate, generated pressure, suction pressure, fluid characteristics in as much detail as possible. Plus type of driver, power supply data if electric motor, and any constraints like preferred type, pump speed and material.
Cheers.......Codey
Good Answers: 32
07/29/2010 3:36 PM
I would add that any Standards that might pertain due to the type of installation such as American Petroleum Institute (API-610) for refinery applications, chemical pump applications might have ANSI, Boiler Feed Water might come under ASTM etc.
There are often certain design requirements such as casing material (no cast iron in hydrocarbon service in refineries or must use chrome-steel for high temperature) and also based on temperature, center-line mounting of casings versus foot mounted.
Spinco
05/21/2011 2:29 AM
Our factory is one of the Chinese pump industries groups, which is the specialized plant making ministry. It is the domestic main enterprise of gear pump profession. Our factory has passed ISO9001: 2000 international quality system authentication, We also passed CE certification, and CCS, BV, DNV, KR, LR, GL, NK, RINA, ABS marine certificates.Welcome to visit our website:www.lfgzfgs.com/lsInfoe.asp?Id=17
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Good Answers: 29
07/29/2010 3:18 PM
And temperature maybe?
07/30/2010 8:48 PM
Direction of rotation? I was on a job where this was miss specified boy did they have FUN!
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Codemaster (1); lyn (1); Patricia_123 (1); RDGRNR (1); Spinco (1); Turbotroll3 (1)
