Previous in Forum: Software   Next in Forum: Human Vibration
How to Find the Torque Required for Gearedmotor?
07/30/2010 3:24 AM
How to Find the Torque?
1)Application-four wheel wagon/Trolley, Drive at one Wheel (both wheels are connect with single shaft)
2)Total mass m=100MT
3)effective wheel dia-Ø430mm
4)max wagon speed 15m/min
Re: how to find the torque required for gearedmotor?
07/30/2010 3:39 AM
Put a lever of known length onto one of the hubs and add weights to the end until it moves. Then do the maths arithmetic (havn't I told you this before?)
It works try it.
Calculations are only as good as the figures you put in, the figures were taken as measuremnets. So why not cut out the middle man and measure the actual thing you want in the first place?
Measurement isn't some sort of dirty word...step away from the computer and do some real measurement, it will be more accurate than any calculation wich ignores friction and a host of other factors.
I mean, if you want the length of a steel bar, you don't measure it's cross section, weigh it, look up the density of steel and then calculate it... ? How accurate do you think the result would be?
Re: How to Find the Torque Required for Gearedmotor?
07/30/2010 7:57 AM
i think you have all the answers if you would expand you thinking a bit,as much as you are looking for the torque to drive your trolley, have you considered the brake to brake your trolley?
P = 2pi T N/60
F = mass x gravity
T = F R
P = F x V
still actual measurement are more accurate than these denotions.
07/30/2010 12:36 PM
Small correction here for F, the force
F = friction coefficient X mass X gravity
RK
07/30/2010 1:51 PM
COOO EEEE.
Am I the only sane one here ?
07/30/2010 8:09 PM
Perhaps! But I wouldn't count on even you being sane.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
brkmech (1); mesulimdluli (1); Turbotroll3 (1); user-deleted-1105 (2)
You might be interested in: Torque Tubes and Torque Arms, Torque Sensors
