Previous in Forum: Non-Liquid 110 psi Nitrogen Pipes   Next in Forum: API 600 TRIM 1 FOR GATE VALVE IN HYDROCARBON
Welding details of LD pipes
07/31/2010 1:54 AM
Is ther any standards to be refered for welding details of large diameter piping say the diameter is 3750mm.
Hobbies - CNC - New Member
Re: Welding details of LD pipes
07/31/2010 11:18 PM
One boilermaker approach which allows hydrotest of welds without filling the whole line is to use butt straps. These are filet welded on each side, both inside and out, so that the enclosed space can be pumped up to demonstrate weld integrity. This is applied in the context of water aqueducts in the US.
08/01/2010 10:58 AM
ver ASME IX para el tipo de pasada segun el espesor y el tipo de electrodos
segun el material base o del ducto
para Ductos de diametros grandes se aconseja usar Semiautomatica
por ser espesores de Chapa pequeños
con esta tecnologia se realiza la soldadura mas rapido y de menor costo
Saludos a todos
Alberto
Register to Reply 2 comments
