Previous in Forum: lt Cable Selection   Next in Forum: Your Comment
Career Advice Needed
08/02/2010 9:11 AM
Dear All,
I have completed my BE in Mechanical engineering and right now i have been working in a multinational organisation(a thermal power plant) as trainee engineer mechanical(boiler).
what i have seen the engineers doing here is planning outages , procurring spares, carrying out modifications, storing critical spares, etc.
the theory which i have studied is not very much applied on daily work but rather its only applied when a critical problem appears other wise manuals are enough to carry out any maitenance activity or even to trouble shoot any problem.
I want to apply what i have learned i dont know much about the turbine side but i guess it would be very much same , alignment ,NDT etc.
I dont want to do these activities as these can be done better by a sound supervisor what i want to do is to apply what i have learned and in doing so learn what i have not learned previously.
i guess what ever these engineers are doing is not an engineers job may be I am wrong but i want to do something that is purely engineer's job and no other person from common man to senior tech or supervisor would be able to do that.
thanks,
regards,
Re: career advice needed
08/02/2010 9:35 AM
Mr.Graduate engineer,
Just know yourself that the first engineer was a man with common sense and efforts. Your so called degrees will be valid and come to operation only in due course of your experience. Your journey is just started and think of what you can learn about and improve your self on understanding of what you have learned and the real world of practice. If you are confident of being a sound engineer having extra ordinary capabilities, prove it to yourself and then to others.
After all man made degrees and prejudices. One got to be really worth about being called an engineer, that is professional talent and hands on work. Assess where you stand at now?
Re: Career Advice Needed
08/02/2010 10:46 AM
I think you'll find that you can learn a lot by getting your hands dirty, even if it seems beneath you at the moment. In the end it will make you a better engineer and eventually manager.
Charlie don't surf.
08/04/2010 2:03 PM
Hi dear Guest,
such your feeling I'd gone by since about four years ago,..........
you have just two options, either * you have to put up, and get rid of your "self-admiration", in this case you'll bear fruits later as Mr. Stevem commented.....Or * you quit and go for another business which match you desire............
hope this helps!!!!!!!!!
Just live and .. Learn!!
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
08/05/2010 5:42 PM
Go to graduate school.
It is better to fail in originality than to succeed in imitation.
08/08/2010 5:39 AM
Please help me find a good one!!!
08/10/2010 11:11 AM
If you truly desire to put your skills that you learned in college to use, get into the r&d side of things. Otherwise, suck it up.
This is the world of engineering.
-kg
08/15/2010 12:04 AM
Recent Grad,
I hope you come back and respond and don't think people here are being harsh on you. However, their comments are valid for working in the power generation industry. I'm around your experience level and graduated college about 2.5 years ago as a mechanical engineer (I still wear diapers). However, I grew up working with my hands as a mechanic, welder, and other "farm boy" stuff. I got into the power industry because during college I did a summer internship at a power plant--I would try to spend at least half my day asking operators and maintenance men questions so I could learn from them.
After school, I took a field engineering position and traveled around doing lots of stuff in plants including commissioning, boiler inspections, outage work, etc. Recently I've hopped on with a very small island utility and have been chasing fires because no engineers here have my plant experience. I've always gotten along with tradesmen and usually bump heads with most engineers. I have a reason for this, if you want to be a good power plant engineer and be respected, you have to learn the ropes and do the time. If you never got your fingers dirty or spent time in operations, you are useless to many people--including people like me that move up quickly because of our experience.
If you want to ever "be in charge", the best thing you can have is field/operations experience. That's how it was in the "old days". Many cultures drifted off track with MBA's and all that BS, but it's being corrected. It's hard to make capital improvement decisions if you don't understand the operations of a plant.
Not only that, if you have enough knowledge to "understand the board" and even run it (with help from others), you will gain the respect of the operators and other tradesmen. Their respect is much more important than those above you; they workers are the ones that actually get stuff done and being able to talk to them for input and observations when problems arise will allow you to get your "real engineering work" done faster, better, and cheaper.
It all ties together in the end. But if you don't have the plant experience, you'll just become another cubicle monkey engineer...and in the deregulated power generation industry of many countries, you may have trouble making a living.
Ali18 (2); Anonymous Poster (1); Economist (1); kgil73 (1); krush (1); stevem (1)
