Previous in Forum: Why Don't We Stop Producing Energy Inefficient Filament Bulbs?   Next in Forum: CT
UPS
08/02/2010 12:28 PM
How to reduce the size of transformer in ups?
padupoi
Re: UPS
08/02/2010 12:33 PM
Decrease the amount of power required out of it.
I think you should analyze the system yourself and come to your own conclusions. We may not be around next semester.
Good Answers: 119
Re: UPS
08/02/2010 2:35 PM
Increase the frequency.
Re: UPS
08/02/2010 2:56 PM
As your post gives no reasoning behind such a rather unusual request, gives no explanation, no figures, no numbers, no values... all you speak about is reducing transformer size. Period. Well, padupoi, the solution is very simple. Just kick out your offending transformer and put in a smaller one. They cost less, too.
Good Answers: 145
Re: UPS
08/02/2010 4:23 PM
These people http://www.capturedlightning.com/ shrink metal coins. The process would probably work on transformers too.
Re: UPS
08/02/2010 8:59 PM
But a smaller transformer and replace it ... That how..... See so Simple.... No need to thank me...
Re: UPS
08/03/2010 12:36 AM
u need to use a better quality winding and core material u can havea forced air cooling by a fan so a smaller xformer will take the load
Please save the power for Next Generation- Do ur bit
Re: UPS
08/03/2010 9:01 AM
Physically , changing a small transformer. Remove the cover panels of UPS. disconnect all wires connected to transformer. Remove all fixing screws/bolts of Transformer and take it out. Fix the new reduced size transformer. Dont ask me whether it will work or not.
Register to Reply 7 comments
Alexander M. Berlin (1); Anonymous Poster (1); BruceFlorida (1); lyn (1); mjb1962853 (1); msmir116 (1); Simon Wan (1)
