Previous in Forum: Welding Procedure Specification (WPS) Question   Next in Forum: Different Chemical Compostion in Cast/Product Analysis
Application of E 6013 and E 7018
08/04/2010 7:20 AM
On what grounds can both E 6013 and E 7018 be used (with justification) in structural steelwork (for steel plates conforming to ASTM A 36); process being SMAW? Or general comparisons between the above two.
Re: Application of E 6013 and E 7018
08/04/2010 10:47 AM
08/04/2010 11:04 PM
For structural steel plates A-36, we recommend using of electrodes E6013. For pressure vessel plates A-516, we recommend using of Low Hydrogen Electrode E7018. For both process you can use SMAW.
See CR4 Thread Welding by 7018 Electrode Without Heating.
08/05/2010 1:07 AM
you can use either of them
amr soliman
08/05/2010 2:01 AM
AS you are aware that E 6013 weldmetal have 60000 PSI Tensile Strength & E 7018 whave 70000 PSI strength.
The weldmetal selection depends on the base metal mechanical & chemical properties as well as thk.
If we look at A 36 E6013 will be appropriate electrode.
08/05/2010 12:56 PM
Disregarding code and when welding upon less than a well prepared (clean) surface, I use a 60xx or P-5 rod for the root pass, chip/wire brush the slag and then 7018. The 60xx rods can "dig" into the base metal better than the 70xx. Using the 7018 rods require a little more pre-cleaning than 60xx. Practice, practice.... trial and error are the best teacher!
me thinks, therefore I am - I think?
Abdel Halim Galala (1); Anonymous Poster (2); leskranes (1); lyn (1)
