Previous in Forum: Mobile OS Installtion   Next in Forum: Install Primavera3.1 in windows7
How to Remove Spaces in a File - Unix
08/06/2010 1:50 AM
Hi
I have a .txt file in that 3 fields are there. Now i want to remove remove extra spaces in the file in all 3 columns.
Please tell the unix command to remove spaces in my .txt file
Good Answers: 244
Re: How to Remove Spaces in a File - Unix
08/06/2010 5:30 PM
It is not clear what exactly you want to do. Here are some tips that can help:
To remove the repeated space:
> cat file | tr -s " "
To remove the leading and tailing spaces:
> cat file | sed "s/^ *//g" | sed "s/ *$//g"
To remove the blank line from a file:
> cat file | grep -v '^$'
You can use awk and regular expression to do this type of things.
- MS
08/09/2010 7:53 AM
hi
i have 3 field in the file
ex :name address city
but the values are like(' Guest ',' mumbai ',' mumbai ')
now i want to remove those spaces contains in each field
Good Answers: 244
08/09/2010 7:16 PM
Try this:
cat file | sed "s/ *//g" > new_file
(there is a space before * and no space between //)
This will remove all spaces from the file.
- MS
08/11/2010 1:10 AM
hi
its not working
09/05/2010 12:02 AM
There is not a single command that will do a complex search and replace. But you can look up how to grep, sed, and awk if must stick with raw unix. You can appropos them to find out how to use them.
Anonymous Poster (2); jsolar (1); msamad (2)
You might be interested in: Columns, GC Columns, HPLC Columns
