We use Mastercam X5 but mostly SolidWorks or CATIA for our Modeling. Yes you can use it to create a model. That is a lot of information to load into a machine when you have the ability to just shoot the code over from mastercam...seems redundant. I have yet to find a machine based software that works as well as Mastercam or Edgecam for surfacing. I would imagine it could be done if the machine has import capabilities for that file type for ex. (SLDPRT.) import with feature recognition software in the CNC control software for the toolpath.
Mastercam Design Tools
Mastercam Design, streamlined 3D CAD software, is included in most Mastercam CAM packages. Mastercam Solids is an add-on that lets you create, import, and machine solid models.
Mastercam Wire
Quick and easy associative wire EDM programming.
Mastercam Mill
Powerful, fully associative programming package for 2, 3, 4, and 5-axis milling.
Mastercam Art
Easily design and machine beautiful 3D work from flat art, drawings, and photographs. Adds on to Mastercam Mill and Router.
Mastercam Lathe
Associative CNC programming system for simple to complex turning.
Mastercam Maintenance
Protect your Mastercam investment by ensuring that you always have the most up-to-date software.
Mastercam Router
Easy-to-use associative CAD/CAM specifically designed for routers.
Mastercam Add-ins
Sometimes that one additional CAD or CAM tool - makes a specific job easier, faster, and more profitable.
well, do you know the application program that can check or verify your programmed mastercam to every mcode and gcode sequence. i saw one but i can't remember whats the name.
follow up question: Where can i get some example drawing that i can practice my programming?
