Previous in Forum: patents   Next in Forum: Essential Variables to Decide MDMT
Using Cu as Alloying Element in High Chrome Alloy Cast Steel
08/07/2010 3:09 AM
Hi, we have 10.9E10 type pulveriser in our power plant. We get grinding balls for pulveriser from one manufacturer which consists about 0.42% Cu in ball material which is High Chrome alloy cast steel of BHN 640 wheather the OEM dosen'n use Cu for the same. I want to know what is the purpose to use Cu in this alloy and what will be the effect on grinding ball regarding wear. Thanks.
Suranjan Chattopadhyay
Re: Using Cu as alloying element in High chrome alloy cast steel
08/07/2010 10:20 AM
Cu slows austenitic transformation, helping the formation of martensites- which is critical for you (thick section castings)
However it is also Austenite stabiliser. The supplier must have chosen the chemistry to suit your application.
