Previous in Forum: Electrical Component   Next in Forum: Loop Sounder Problem
Synchronization of Two Generators
08/07/2010 5:29 AM
hi sir,
please tell me sychronization of two generators connected to one MDB.two generators are same rating.
Good Answers: 11
Re: Synchronization of two generators
08/07/2010 6:03 AM
To synchronize AC generators several important factors must be the same.
1- The phase rotation of both generator systems must be the same.
2- The AC voltages of both generators should be equal.
3- The frequency of the incoming generators must match when synchronized ( in practice the frequency of the incoming generator is 1 to 2 Hz higher than that of the online generator. This can be observed with lights or by using a system chroscope.)
4- The speed and output voltage of the incoming generators are slightly higher to prevent it from becoming a load to the system when it is connected.
for more information see here too.
http://cr4.globalspec.com/thread/57066#newcomments
08/07/2010 7:47 AM
Thank u sir,
i need clear explaination of if two generators connected to one MDB,what will be the synchronization operation.
