Previous in Forum: Filler Wire for Welding Copper Pipe to SS Pipe   Next in Forum: Steam Transposation
Land Cruiser Diesel Engine
08/08/2010 1:10 PM
CR4 crew
I have problem with land cruiser diesel engine 6 cylinders , in morning time i run the car normally no problem after few hours i stop the i try again to run it noway until to push the car to start again.
can you tell me what is the problem .
Note i repaire the fuel pump and injectors i fix new fuel filter and clean fuel tank.
Thanks
Good Answers: 141
Re: Land Cruiser Diesel Engine
08/08/2010 5:01 PM
Check the system for leaks in the fuel system, or isolated air pockets. I usually fix this injector by injector. Let the engine run and loosen the fuel connector nuts one at the time - if bubbles appear, air is trapped. When the diesel flows tighten the nut - and do the next one. When the injection pump has a air plug- do this first till diesel flows. Little at the time.
PS. If the engine still has a manual pump, you can do this without running the engine too. This is the main problem for whatever diesel engine. For more help, tell us the year of the engine and if it has hydraulic operated valves.
Is it one with glow plugs? And if yes, how is the glow time controlled.
1. Check for Air
2. Check if glow system works properly ( it could give wrong info - especially critical for engines with high mileage)
3. Valve clearance. If not hydraulic
4. If the engine smokes (black, or white), check pump timing.
Plenty of room here
Good Answers: 58
08/09/2010 10:40 AM
Just a guess here and based on minimum info, if you have to "push the car to start again" first thing that comes to my mind is a bad battery or alternator.
Does it crank (starter turns) when you try to re-start after you have run it and it does not start up?
Register to Reply 2 comments
You might be interested in: Fuel Testers, Fuel Cells, Fuel Additives
