Previous in Forum: Gain in dB   Next in Forum: Profibus Data Sheet
WIFI Monitoring and Management Software Needed
08/09/2010 11:47 PM
hi , i have been trying in vain to find out a utility for my external wifi usb adapter alpha make...using rtl 8187 chip.
i had one such utility that came with a alpha high power adapters of some other model which could indicate all the available wifi networks including the hidden nameless types and their power strength mac id details etc. and had the provision to connect to a network from the utility itself by double clicking the available network of my choice. but unfortunately got deleted .
the cd that came with my model has just the drivers only without this excellent utility. i tried to search this utility for rtl 8187 chips but all that i could find was drivers only. i am using vista os.
pl help me by giving details about the source. thanks
Re: WIFI monitoring and managemnt software needed
08/09/2010 11:56 PM
What does the, "wifi usb adapter alpha make...using rtl 8187 chip." site say about this? Do you have customer support?
This statement says it all, "i had one such utility that came with a alpha high power adapters of some other mode"
What other mode?
Your turn.
Good Answers: 60
Re: WIFI Monitoring and Management Software Needed
08/12/2010 1:37 PM
any use ?
  1. Asus Wifi-AP Solo with rtl8187 chip - FedoraForum.org 1 post - 1 author - Last post: 12 Nov 2006Asus Wifi-AP Solo with rtl8187 chip Installation Help.
    forums.fedoraforum.org › Fedora Support › Installation Help - Cached - Similar Bad wifi connexion on F10 X86_64 (wifi chipset wg111v2, and module ...‎
    MSI wind RTL8187 wifi problem‎
    gateway rtl8187 wireless help PLEASE......pretty please ...‎
    RTL8187 in Fedora 7‎
    More results from forums.fedoraforum.org »
  2. RTL8187 in Fedora 7 - FedoraForum.org 15 posts - 4 authors - Last post: 15 Jun 2007Has anyone been able to get the rtl8187 chip working in Fedora 7 yet. I never managed to get it working in fc6. Any help on this topic would ...
    fedoraforum.org/forum/showthread.php?t=156630 - Cached Wifi Problem Fedora 12 and RTL8187 - Page 2‎ - 6 posts - 22 Jan 2010
    rtl8187b Mini-Howto.‎ - 2 posts - 3 Apr 2008
    Kernel panic with rtl8187 and 2.6.24‎ - 13 posts - 23 Mar 2008
    More results from fedoraforum.org »
  3. New rtl8187 rfkill support blocks my wlan for good. - Patchwork 3 Dec 2009 ... In any case, the rkill code works here (up to date fedora 12 + ... get some random bits off the chip and lie to the rest of the system about ...
    patchwork.kernel.org/patch/64501/ - Cached
  4. Bug #293946 in linux (Ubuntu): "realtek rtl8187 weak signal ... 5 Nov 2008 ... I too have an RTL8187 chip on my Asus P5K Deluxe Motherboard. ..... I also tested openSUSE 11.1 (32 and 64 bit) and Fedora 11 (64 bit), ...
    https://bugs.launchpad.net/ubuntu/+source/linux/+.../293946 - Cached - Similar
  5. Not Working RTL8187 with patched r8187 on clean install UBUNTU 9 ... 15 posts - 3 authors - Last post: 28 May 2009I use Fedora and have never had a problem. ... May 28 00:23:22 ghost kernel: [ 4459.586159] rtl8187: MAC chip version: 04 ...
    forum.aircrack-ng.org/index.php?topic=5441.0 - Cached
  6. Free rtl8187 Download - linux software The rtl8187 kernel module with Fedora 7 x64 does not appear to .... FTDI Chip FT232R Driver 1.35r1 Linux Download - FTDI Chip USB Drivers (Cache) (Images) ...
    linuxidx.com/linux.php?q=Free+rtl8187+Download+-+linux+software
  7. Fedora - Realtek 8187 wifi card problem I also tested openSUSE 11.1 (32 and 64 bit) and Fedora 11 (64 bit), ..... It has Realtek RTL8187 chip. I have the same problem. This Wifi card can pick up . ...
    linuxidx.com/linux.php?q=Fedora+-+Realtek+8187+wifi+card... Show more results from linuxidx.com
  8. Fedora 10 airodump-ng Error 7 posts - 5 authors - Last post: 21 Aug 2009Interface Chipset Driver wlan0 Realtek 8187L rtl8187 ... this article thru google [ http://www.linux-archive.org/fedora-...g-iwl4965.html ]. ...
    www.linuxquestions.org › ... › Linux - Laptop and Netbook - Cached - Similar
CR4 Admin: removed broken links and a whole bunch of redundant links as well
Good Answers: 60
08/12/2010 1:38 PM
and
  1. Software - Realtek Realtek RTL8111E Single-Chip Gigabit Ethernet Controller Wins "Best Choice of COMPUTEX ... Realtek Demonstrates Automatic Power Saving Technologies For ...
    www.realtek.com/.../downloadsView.aspx?Langid... - Cached
  2. Download Realtek RTL8187 5.1230 Driver for Windows 9X/ME/NT/2K/XP ... 11 Jul 2006 ... Realtek devotes itself to offering a comprehensive range of ICs of exceptional value for the communications network, computer peripheral, ...
    drivers.softpedia.com/.../REALTEK/Realtek-RTL8187-51230.shtml - Cached - Similar
  3. Download REALTEK RTL8187 Wireless USB 2.0 Driver 6.1281.0130.2007 ... 8 Feb 2007 ... Download REALTEK RTL8187 Wireless USB 2.0 Driver 6.1281.0130.2007. ... The Realtek RTL8187L, fully complying with IEEE 802.11a/b/g ...
    drivers.softpedia.com/.../REALTEK/REALTEK-RTL8187-Wireless-USB-20-Driver-6128101302007.shtml - Cached - Similar Show more results from drivers.softpedia.com
  4. REALTEK RTL8187 Wireless LAN Driver and Utility Software Informer ... If you are looking for REALTEK RTL8187 Wireless LAN Driver and Utility, you may try searching for a download link using Google. ...
    realtek-rtl8187-wireless-lan-driver-and.software.informer.com/ - Cached - Similar
  5. Realtek RTL8187 Wireless 802.11g 54Mbps USB 2.0 Network Adapter ... 2 Jan 2010 ... That installed without fuss and the Realtek RTL8187 has been working ever since. And for $20 they even throw in a 5 dBi whip antenna which ...
    download.cnet.com/Realtek-RTL8187.../3000-2112_4-147310.html - Cached - Similar
  6. RealTek RTL8187 driver This page contains RealTek RTL8187 drivers for free download for several os include Windows, Linux, FreeBSD, MacOS and other.
    www.driverstock.com/RealTek-RTL8187.../18.../index.html - Cached - Similar
  7. Realtek drivers REALTEK RTL8187/RTL8187L Wireless (Drivers) .... REALTEK RTL8192U Wireless 802.11n USB 2.0 Network Adapter (Drivers) ...
    www.station-drivers.com/page/realtek.htm - Cached - Similar
  8. Realtek RTL8187 Wireless 802.11g 54Mbps USB 2.0 Network Adapter ... Realtek RTL8187 Wireless 802.11g 54Mbps USB 2.0 Network Adapter Free download from Driver column of Downloadatoz.com.
    www.downloadatoz.com › ... › USB Drivers › NON Drivers - Cached - Similar
  9. Asus WIFI AP Solo - Realtek RTL8187 - Tech Support Guy Forums 3 posts - 2 authors - Last post: 8 Mar 2008Hi, my system AND my problem is almost the same. I have rebuilt my wlan today with new hardware and WPA2. all of my xp machines works fine ...
    forums.techguy.org › Operating Systems › Windows Vista - Cached - Similar
  10. |MG| Realtek RTL8187 USB Wireless LAN (ME/2000/XP) 1.221 Download 28 Jun 2006 ... Download Realtek RTL8187 USB Wireless LAN (ME/2000/XP) 1.221 ...
    majorgeeks.com/Realtek_RTL8187_USB_Wireless_LAN_ME2000XP_d5165.html - Cached - Similar
1
6
7
8
9
10
