Previous in Forum: Troubleshooting Contactors   Next in Forum: Main-tie-main Arrangement with Tie Breaker Normally Close
Starter
08/11/2010 11:57 AM
why the value of current in star delta starter is 1/3
Good Answers: 181
Re: starter
08/11/2010 12:07 PM
It isn't it's 0.578 of FLC
The inverse of root3
Good Answers: 804
Re: starter
08/11/2010 6:02 PM
The contactor that shorts the Star points of the motor during starting can be sized to 33% of FLC, but that's because all it is going to carry is that Star current. generally though because it needs to be mechanically interlocked with the Main contactor, the mechanical interlocks end up requiring them to be the same physical size.
But as to why, read this, it explains it all.
http://www.lmphotonics.com/star_delta.htm
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: Starter
08/12/2010 1:08 AM
i m sorry if u couldnt read this...jus hated to type.....
shamith gambhir, electrical engineer
Good Answers: 804
Re: Starter
08/12/2010 2:34 PM
For your future reference;
When you first post an image in this forum, they give you handles on the image to allow you to change the size before finalizing the post. You can also still do it in Edit for the first 15 minutes after posting. That's handy when you can't read something or when you don't want it to be so big.
Re: Starter
08/12/2010 3:17 PM
sorry for the disappointment guru, i really dint want tht to happen.....jus had no patience to wait n edit... jus uploaded watever i could....
cant u view the image after u save it in your comp.......is it tht bad....i havent checked it myself....
anyway thanks for the suggestion..i hope i ll do tht nxt time............
Re: Starter
08/12/2010 1:41 AM
JRaef (2); SHAMITHGAMBHIR1 (3); TonyS (1)
