Previous in Forum: Approvals for Hazardous Areas   Next in Forum: Calculation of Diversity Factor and Demand Factor
What is NGR (Neutral Grounding Resistor)?
08/13/2010 2:32 AM
Why is it is used for MV and HT Lines only?
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
Re: what is NGR (Neutral Grounding Resistor)?
08/13/2010 5:54 AM
It can be used for the LV system also.
But it since it is a long time practice we all are used to solidly earthed system in LV.
It is used mainly in the HV system......................because
to protect all the HT motors and other outgoing feeders which are designed to withstand low earth fault current and also in any system most likely fault in the system is earth fault.
with NGR are we are limiting the earthfault current so that all these equipments can be protected
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Good Answers: 170
Re: What is NGR (Neutral Grounding Resistor)?
08/13/2010 10:35 AM
The topic is too large to be explained here. Please visit this website:
www.i-gard.com
They have some very good publications on the subject.
Good Answers: 244
08/13/2010 1:34 PM
It is already mentioned by sms149 that 'it can be used for the LV system also'. In addition, I would like to clarify one more thing. If you use NGR in a system, you cannot use the single phase (line to neutral) of the system. Generally, the single phase is used in low voltage electrical system, and it is the reason the use of NGR is not common in low voltage. However, in the process industries NGR is used in 3 phase low voltage system and in this case, all single phase loads are provided from the line to neutral of a separate transformer whose neutral is solidly grounded.
See the previous threads:
http://cr4.globalspec.com/thread/56612/Neutral-Grounding-Resistor
electricalexpert65 (1); msamad (1); sms149 (1)
