Previous in Forum: Generator - Alarms of a Deutz E11.4 Genset   Next in Forum: Multi Split Unit vs. Variable Refrigerant Flow Unit
Shear Rate Calculation
08/13/2010 4:56 AM
Hi CR4 Readers,
I wish to calculate the shear rate of an agitator impeller with the units of 'per second' (s-1). Please advise a formula for this. The hydrofoil impeller is 1.76m diameter an running at 70rpm. I believe the answer should be around 4 s-1 .
There also appears to be another shear rate expressed in units of m/s. The formula is T = pi x D x N/60.
Thanks for your help.
Good Answers: 137
Re: Shear Rate Calculation
08/13/2010 6:26 AM
Formula is √(W/V/μ) where W = power, V= volume, μ = dynamic viscosity. All in consistent units of course. You can work it out from first principles assuming laminar flow.
4 s-1 seems very low, even for say a flocculation stage on water treatment. Estimating your tank volume at 10 m3 and assuming viscosity as water (1 cP), I make that only 0.2 watt (into the water) to give 4.5 s-1 .
Don't know about the other shear rate.
Cheers.......Codey
You might be interested in: Centrifugal Pumps, Bit Error Rate Testers, Impellers
