Previous in Forum: Relief Valve   Next in Forum: Heat Transfer
3/8" Threaded Rod
08/15/2010 1:03 PM
how much weight will a 3/8" mild steel, (Home Depot), threaded rod support?
Re: 3/8" threaded rod
08/15/2010 1:54 PM
Somewhere around 600# is max load for 3/8" mild steel TR.
I'd limit the load to 1/2 that value if there is no flexing or sideways movement in service.
Be safe.
08/15/2010 2:43 PM
Thanks. I'm a builder and we are hanging 4 300#chandiliers. We have existing steel trusses to attach to. The bottom chord consists of two 6x6x3/8 angles back to back with a 3/8" space between the verticle legs...thus the 3/8" all-thread. We will use two per chandilier plus 7/32" air craft safety cable tethered to the top chord.
08/15/2010 7:01 PM
I'm not qualified to advise you, and knowing where you are would help.
I can do things back on the farm that I can't do in town.
Will it be inspected by anyone?
Register to Reply 3 comments
You might be interested in: Threaded Inserts, Threaded Rod, Nuclear Services
