Previous in Forum: Three Electrical Terms   Next in Forum: Why Maintain Constant DC Link Voltage in dstatcom While Compensation?
Battery Current Monitoring Relay
08/19/2010 2:11 AM
Dear All, I am having a requirement to monitor the traction motor current of Battery operated 2 ton vehicle & trip the vehicle at set value of current. Normal current drawn is 25 A from the 24 V /300 AH battery but in case of overcurrent I need a tripping contact from relay.
Pl. suggest the product with complete details
Thanks
Thanks
Good Answers: 266
Re: Battery Current Monitoring Relay
08/19/2010 11:53 AM
Do you need to monitor it or just have it cut out? What type of speed controller is on the vehicle? If it is an electronic speed control some have pots that enable you to set a thresh hold current. It will trip out on over current. Some reset after taking your foot off the accelerator petal. Some reset by placing the vehicle in neutral.
08/19/2010 11:59 AM
Vehical having a fix speed of 10kmph which is driven through curtis make DC drive having max acceleration time 3.8 sec At starting current drawn by vehicle : 23-25 Amp In normal running current drawn is : 16-18 Amp But in case of any jamming/overloading due to improper break release or failure / worn out bearings of load wheels vehicle draws 40-50 amp which results in failure of DC drive Thus, i want to provide indication / tripping at overloading
Thanks
Good Answers: 266
08/20/2010 8:15 AM
What model Curtis controller? Several of their models have current limiting pots that are accessible and can be set for your needs.
08/20/2010 12:08 AM
If you put a Thermistor in line with the motor drive, it will not allow the motor to draw more than the desired current.
A cheaper solution is thermal overloads on the motor contactor. The motor draws too much current, the overloads overheat, and the circuit is broken. After a set time, the overloads reset and the circuit is made, until mechanical failure occurs.
The downside of the overloads is they don't allow the battery to be drawn down (usually .8) low enough to drop the supply voltage.
It is a challenge; because, as the supply voltage drops, the required current increases, the motor gets hotter, the contactor overloads heat up....
08/20/2010 5:57 AM
An electronic circuit with a few transistors and resistors could be put along with your existing motor which would in turn sense rise in current drain of more than 25 amps and trigger the tripping contact. mann935
Anonymous Poster (1); dhanesh.koshti (1); mann935 (1); ozzb (2)
