Previous in Forum: Car Brake   Next in Forum: Why is Connecting Rod Cast Iron?
13 comments
Pressure Regulator Cv for Natural Gas Train
08/19/2010 2:48 AM
Dear All,
Please help me calculate the Cv for pressure regulators of a natural gas trains which has two pressure regulators for a two stage reduction.
first stage condition
IP: 25 kg/cm2
OP: 4 kg/cm2
Line size: 1" NB
Second stage condition
IP: 4 kg/cm2
OP: 0.5 kg/cm2
Flow: 1250 Nm3/hr
Line size: 1" NB
Also, what would be the velocity of natural gas in each conditions.
please treat me as a layman and help in this,i might have posted insufficient details.
Thanks in advance,
Santosh J
Nothing is impossible, even impossible says I M Possible
Re: Pressure Regulator Cv for Natural Gas Train
08/20/2010 12:09 AM
I'm not likely the ultimate one to help you, but it would be better if you define a couple of terms:
Cv could mean lots of different things to different people.
A train is a vehicle that runs on rails. Other multiple things connected one after the other are also referred to as trains, but trains of (whatever).
Good Answers: 27
08/20/2010 5:55 AM
Santy
The Cv of a valve is the flow of water at 60 degF in US gallons per minute which will result in a one psi pressure drop with the valve wide open.
Cv = Q x (g/delta P)0.5 Where Q is in usgpm, g is secific gravity and delata P is the pressure drop across an open valve.
You should be able to look up the Cv of your valve quite easily.
I have no special talent. I am only passionately curious. Albert E
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
08/20/2010 9:25 AM
The rated Cv for your regulators should be available if you know the manufacturer. Check out the Fisher regulator/control valve site, you can get to it through www.emerson.com and they have the equations you need to figure this out. You'll probably need the temperature of the gas as well at a minimum. I would not use the liquid equation for this application.
Money doesn't talk, it screams in your face.
Good Answers: 27
08/20/2010 9:51 AM
"I would not use the liquid equation for this application"
Oops - really should read the question properly and apply mind not a***.
Flow Coefficient - Cv - for Air and other Gases
For critical pressure drop the outlet pressure - po - from the control valve is less than 53% of the inlet pressure - pi. The flow coefficient can be expressed as:
Cv = q [SG (T + 460)]1/2/ 660 pi (5)
where
q = free gas per hour, standard cubic feet per hour (Cu.ft/h)
SG = specific gravity of flowing gas gas relative to air at 14.7 psia and 60oF
T = flowing air or gas temperature (oF)
pi = inlet gas absolute pressure (psia)
For non critical pressure drop the outlet pressure - po - from the control valve is greater than 53% of the inlet pressure - pi. The flow coefficient can be expressed as:
Cv = q [SG (T + 460)]1/2/ [1360 (dp po)1/2] (5b)
where
dp = (pi - po)
po = outlet gas absolute pressure (psia)
You will find an online calculator here
08/20/2010 3:00 PM
Regulators control pressure not flow. Cv is related to flow. You have stated that your flow is 1250 Nm3/hr. Bernoulli said flow in equals flow out. Your flow before the first regulator, between regulators, after the second regulator would equal the equivalent of 1250 Nm3/hr at .5 kg/cm2. You know the ID of the pipe or tube. The velocity in any section of the system is the specific density (Nm/meter) at the existing pressure divided into the flow (eg. if one meter contains (for example only) 4 Nm/m @ .5 kg/cm2 then 1250/4 = 312.5 meter/hr. The flow will be slower at higher pressue. Tom
08/21/2010 2:29 AM
Dear All,
Thank you for your prompt reply and support.
@dkwarner.... lol!! i dot know if you are trying to pull my leg....but with due respect, i guess everyone else who replies understood what i meant by Cv & a gas train.
@Kaisan.....thanks for the formula, had got that one from some reference books and earlier forums posted on this website, i did work out some calculations based on it, am pasting the same below can you please if possible check them for me if i got the concept right??
@Tom.... got that one.....can you please check my below calculations and let me know if am right / wrong or need to tweak a little......
Thanks in advance all.
My calculations below:
Inlet pressure at PRS is 25 kg/cm2
First stage reduction is 25 kg/cm2 to 4 kg/cm2
Second stage reduction is 4 kg/cm2 to 0.5 kg/cm2
Process requirement is 0.5 kg/cm2 with 1250 Nm3/hr. This also becomes the outlet condition of 2nd stage regulator.
Now to get flow requirement at outlet of 1st stage regulator
P1V1=P2V2 considering constant temperature at inlet and outlet of regulator
Where,
P1 = the absolute inlet pressure of 2nd stage regulator
P2 = the absolute outlet pressure of 2nd stage regulator
V1 = the flow of gas at inlet of 2nd stage regulator
V2 = the flow of gas at outlet of 2nd stage regulator
Hence,
(4 + 1.033 kg/cm2) x V1 = (0.5 + 1.033 kg/cm2) x 1250 Nm3/hr
5.033 x V1 = 1.533 x 1250
V1 = 381 Nm3/hr
Conditions at outlet of 1st stage regulator
Outlet pressure: 4 kg/cm2
Flow: 381 Nm3/hr
Cv of 1st stage regulator
Since, Inlet pressure is greater than 2 times outlet pressure we use the following formula
Cv = {Q [SG (T + 460)]^0.5} / 660 (Pi)
Where,
Q = Flow in CFH
SG = Specific gravity
T = Temperature in (°F)
Pi = Absolute inlet pressure (psia) which is actual pressure + atmospheric pressure
Converting 381 Nm3/hr to SCFH
Now 381 Nm3/hr is at standard condition of 1 atm and 0 deg.C
Converting Nm3/hr to m3/hr
Q(act) = Qn x T(act)/(273 x P(act))
Where,
Q(act) = m3/hr
Qn = Nm3/hr
T(act) = Temperature in K
P (act) = Pressure actual (atm)
Considering operating temp as 30 deg.C = 303.15 Deg.K
4 kg/cm2 = 3.871 atm
Q(act) = 381 x 303.15 / (273 x (3.871 +1)
= 115500.15 / 1329.783
= 86.85 m3/hr
Now,
1 m3/hr = 35.314 scfh
Therefore,
86.85 m3/hr = 3067.079 scfh
Specific gravity of Natural gas is 0.7
1 deg. C = 33.8 Deg.F
Back to Cv formula
Cv = 3067.079 [0.7(86+460)]^0.5 / 660 (355.58 + 14.7)
= 59961.198 / 244384.8
Cv = 0.25
Cv of 2nd stage regulator
Where,
Q = Flow in CFH
Converting 1250 Nm3/hr to SCFH
Now 1250 Nm3/hr is at standard condition of 1 atm and 0 deg.C
Where,
Q(act) = m3/hr
Qn = Nm3/hr
0.5 kg/cm2 = 0.484 atm
Q(act) = 1250 x 303.15 / (273 x (0.484 +1)
= 378937.5 / 323.232
= 1172.33 m3/hr
Now,
Therefore,
1172.33 m3/hr = 41400.44 scfh
Back to Cv formula
Cv = 41400.44 [0.7(86+460)]^0.5 / 660 (56.89 + 14.7)
= 809375.95 / 47249.4
Cv = 17.13
Good Answers: 27
08/23/2010 5:49 AM
Santy
Have no time at the moment but a quick look indicates that you are mixing things up a bit. V1 and V2 are volumes, not flows.
Nm3/hr is at a set of known conditions, the actual volume flow will vary with pressure, but the normalised volume flow remains the same across the sytem.
As Tom says, the flow of 1250 Nm3/hr (44143 Ncuft/hr) is the same across the system.
08/23/2010 9:08 AM
I agree with Kaisan and others, you should have a constant 1250 Nm3/hr passing through each regulator as the system needs flow in = flow out unless your regulators are physically unable to do that (possible but not likely in this case). I would convert the 1250 Nm3/hr to your actual cubic meters and then repeat the calculations.
08/23/2010 9:09 AM
Oh and thank you for responding to our questions and keeping the thread alive, that can be somewhat of a rarity.
08/25/2010 2:10 AM
Sorry for that goof up. Thanks again Kaisan, Betomachine and everyone else.
That means the flow rate remains the same at the inlet and outlet of a pressure regulator. Is it under some defined conditions or it always like that?
I am confused. As per the conditions in my question the process requirement is 0.5 kg/cm2 with 1250 Nm3/hr flow rate. How do i ensure that the inlet flow of the second stage regulator and the inlet flow of the first stage regulator is also 1250 Nm3/hr.
I may be asking too many dumb questions here, but would like to get my this thoroughly cleared. Referring a lot of books and self learning, but actual people like you can make it easy to understand with examples and experience.
Regards,
08/25/2010 10:59 AM
Perhaps I can help after all. The N in 'Nm^3/hr' means normalized, or converted to standard pressure. One Nm^3 is the same amount (mass, weight, number of molecules) of gas at any pressure. At the higher inlet pressure, the actual volume will be smaller than the actual volume at the reduced outlet pressure, but the flow in molecules per second MUST be the same at the input as the output. Otherwise you have a leak, or are magically producing new molecules!
08/26/2010 3:40 AM
thanks dkwarner.
So should i consider the flow rate for both the pressure regulators as 1250 Nm3/hr?
What if the flow receiving at the inlet of 1st stage regulator say from an MRS/DRS (or any other source) is higher than 1250 Nm3/hr.
Could you also help me on how to size the pressure regulator?
Regards,
08/26/2010 11:50 AM
IF your process actually uses 1250Nm^3/hr of gas, then that quantity (mass, not volume) must flow through every stage of the system, including the regulators, from whatever source is used up to the manifold or other point where the flow splits into more than one stream.
Under steady state conditions (after initial surges at turn-on), the flow at the input will automatically adjust to conditions at the output. If you stop the flow after the regulators by turning off the low pressure valve, the flow at the input must also stop (a very short time after the output is stopped)! The flow at the input can never be different than the flow at the output except briefly during more-or-less sudden changes in either the input pressure or the output pressure, such as initial start-up.
As you saw in my first post, I am not experienced in fluid flow calculations, so no, I can't help in sizing the regulators. I would expect the regulator vendors to be willing to help with that, although there is a good possibility that they might recommend a larger unit than needed, to maximize their sales. But then oversized is definitely preferable to undersized!
Register to Reply 13 comments
betomachine (3); dkwarner (3); Kaisan (3); santy1980 (3); Tom Kreher (1)
You might be interested in: IP Cores, Stage Lamps, NEMA and IP Enclosures
