Previous in Forum: Vintage British Grease Fittings   Next in Forum: 1966 K Code Mustang
13 comments
Battery Swapping Between Vehicles?
08/19/2010 9:21 AM
The other day I was in a hurry so I swapped the 12V battery from my Jeep into my daughters 2005 Mitshubishi Eclipse. The Jeep battery was a bit shorter, but fit alright. Her car started right up. I did get the correct battery for her car. Could the Jeep battery or anything in the Mitshubishi be damaged when a battery is swapped like this?
Re: BATTERY SWAPPING BETWEEN VEHICLES?
08/19/2010 9:33 AM
Since you didn't tell us which battery was used, we cannot provide a good answer. Now that you are not in such a hurry go out and solve this problem.
Good Answers: 48
08/19/2010 9:41 AM
As long as they're both 12v, and you don't damage the connectors in your hurry, then no.
Re: Battery Swapping Between Vehicles?
08/19/2010 1:00 PM
Oh, no!
Battery swapping like this is the leading cause of car trouble.
What ever troubles the Jeep has, the Eclipse now has. The contagions of many car problems lay silent in the battery, waiting for just the opportunity you have given them. The jump start is the usual method, but a battery swap...
On second thought, you should be fine.
Good Answers: 48
08/19/2010 1:56 PM
Not that dreaded auto battery virus again? Windows won't open! Doors won't close! Turn the starter and it all freezes!
Reply Off Topic (Score 4)
08/19/2010 2:09 PM
I see, Holzfeller, that you are familiar with the syndrome.
Starter motor failure, drips of power steering fluid, goes through U-Joints, poor mileage and performance... nobody at work ever wants a jump from me, nor even wants to park next to my car!
Good Answers: 60
08/19/2010 4:59 PM
you lot need to get out more lol the only difference in battery could be capacity,
08/20/2010 5:16 AM
Oh Dear! You forgot that whatever problems the Mitsubishi had, are now transferred to the Jeep too! I suspect the vehicles will be fine, me,,,,,,,, I'm not so sure. Have a great day guys.
h
Good Answers: 60
08/20/2010 2:06 AM
you might loose the memory on your radio, and also possibly some information on the engine management, but the ecu will learn the data again.
the radio code can be difficult if you dont have it written down somwhere.
other wise there is no problem apart from the capacity of the battery
08/20/2010 6:07 PM
If the battery mounting/retaining facilities are not compatible, the improperly secured battery could tip over causing a fire and loss of the vehicle and occupants. Is that serious enough for you?
If the resulting fire happened in the wrong place, such as in busy rush hour traffic, on an express way, other people could be injured or killed also. If the fire started or propagated to a forested area, the resulting fire could start a forest fire, burn millions of acres and cause the loss of uncounted woodland homes and their occupants.
But if nothing like that happened, the most likely result is loss of radio programming and having to reset the clock.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Good Answers: 48
08/20/2010 7:03 PM
Sounds a bit far-fetched and over-dramatic to me. Auto batteries are not that different in size (unless you're stupid enough to try fitting a 6v motorbike battery), so they will either not fit into the space, or if they do they will not tip over. Besides, the electrolyte will not flood out, and it is more corrosive than explosive.
Good Answers: 48
08/20/2010 4:03 AM
Battery capacity could be a problem if it is too small, then you might have trouble starting, especially if it doesn't start first time, but it won't cause any damage (unless you resort to a 'Basil Fawlty' when the car doesn't start). Too much capacity is not a problem, the car only takes what it needs, again no damage.
Radio codes are a pain!
08/20/2010 2:53 PM
Thanks for your input. Goes to show the people at the auto parts stores don't know what they're talking about.
Good Answers: 60
08/20/2010 3:54 PM
they just want to sell you batteries.
Anonymous Poster (3); Doorman (2); Holzfeller (4); peterg7lyq (3); Turbotroll3 (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
